Runaway dt1e!
- msavitt
Runaway dt1e! was created by msavitt
Experience the runaway engine even when switching ignition off. Here’s state of motor which starts and runs and performs terrific besides this (a how was the other half of the play mr Lincoln)
- new top end, base gasket with yanabond on both aides
- new genuine Yamaha crank seals properly and gently installed with crank puller vs hammer
- carb cleaned and adjusted, flange and insulator filed flat since all were warped
- timing properly set with dial indicator
- million other things that don’t relate to engine
Knowing all of this, does anyone have any ideas where I might focus to find an air leak?
epoxyed tank seam and thought I was done, but no such luck!
thanks for your help!
07 May 2021 10:42
- msavitt
Replied by msavitt on topic Runaway dt1e!
Ps plug looks pretty good after ride.
07 May 2021 10:51
Replied by RT325 on topic Runaway dt1e!
Never had that so only guessing at something like a plug hole that's been hellicoiled & the end of hellicoil is 'just' poking out & glowing. Hell i dunno--head gasket overhang, but they're sort of folded over so wouldn't happen. Is throttle closing off to an idle.
07 May 2021 14:47
- msavitt
thanks RT
I am going to pop the head for sure to take a peek and then put it back together and try to pressure test it again.
the condition was like a runaway diesel, hard to imagine that I have an air leak large enough, but then again what the heck do i know! will report back
07 May 2021 18:26
- Pete-RT1
Replied by Pete-RT1 on topic Runaway dt1e!
I would do the pressure test before you take off the head, that way you haven't changed the fault conditions.
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, Swoop56, yamahahaha, Snglsmkr, Schu
08 May 2021 01:23
- msavitt
Good point, plan revised!
08 May 2021 02:48
- asco
Replied by asco on topic Runaway dt1e!
You said; DT1-E
I would ask if the cylinder is piston port?
Some change to Reed valve ( big leaker ).
yama bond base gasket - huh???
your air leak is in the carburetor flange.
asco
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
08 May 2021 07:40
- msavitt
Hi asco - yes a 1971 DT1E
No reed valves, piston ported
I put a very light smear of Yamabond on both sides of the cylinder base gasket so it would seal perfectly against the incredibly cleaned mating surfaces
Def could be carb flange as the PO warped the crap out of the flange by ~1mm which I had to remove with a very large file. It def was flat after filing, but definitely worthy of another go through once i pressure test.
08 May 2021 07:46
- msavitt
you were right asco!
flange that i had flattened was warped
stuffed a fat oring into groove on carb flange and it rode perfectly!
I think this bike is done
thanks a ton
martin
thanks a ton
martin
08 May 2021 15:21
