Crank shaft O ring missing
  • DT400Phill
  • DT400Phill's Avatar Topic Author
Crank shaft O ring missing was created by DT400Phill
On re assembling my DT400B engine i noticed an O ring shown on the assembly drawing from the parts list. This O ring is shown on the right hand side of the crank shaft but was not on the shaft when i took it apart and i cant see exactly where it should be placed.
24 Aug 2026 14:01 #1
Replied by RT325 on topic Crank shaft O ring missing
Fits on the shaft before you put the gear on. Gear is recessed to compress the Oring. Check the gear incase it's still stuck in the recess. That's without looking just going by memory. My theory "maybe misguided" is that "if it's missing" & you're "stuck for your weekend ride"--provided crank nut is "tight" then no oil can get along & up past the bearing as it's sitting bolted 'nutted" hard against the crank wheel. Should still fit it though in the end. OK ignore all that & reffer to first sentence.
24 Aug 2026 15:55 #2
  • DT400Phill
Replied by DT400Phill on topic Crank shaft O ring missing
Okay, thanks, that makes sense. I have a selection of O rings available so should be able to install. Still a lot of other work to do before I can ride off into the distance.
24 Aug 2026 17:01 #3
