Re:Just got a new project
- 2fishkev
Replied by 2fishkev on topic Just got a new project
Good work! Time to give the elbows a shot of grease before they run dry. In regards to the frame, maybe a combination of Emory cloth strips, sandpaper, and wire wheels would get you where ya want to be. If only to get to rider condition, then I wouldn’t be so concerned about complete removal. Some of that 50 year old paint is still doing its job and is a pain to remove, even with aircraft paintstripper. It still works well as a primer. Some here have just roughed up the surface well with 3m pads and blended the edges and repainted. I just tried some old naval jelly on a pipe and had success in removing the last bit of rust from the surface. Maybe you could lay your hands on some and use it on the rusty parts. Good luck and keep us posted.
29 Mar 2020 08:06
#31
- shyted
Replied by shyted on topic Re:Just got a new project
30 Mar 2020 06:25
#32
- mdscott
Replied by mdscott on topic Re:Just got a new project
Thumbs up on you tank work,
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
30 Mar 2020 07:51
#33
- Godlygaz
Replied by Godlygaz on topic Re:Just got a new project
Edit: terrible at explaining this
So I have an M10 bolt which I have tried using as a puller, but it doesn't 'like' being screwd in.. could the thead pitch or something be different?
- SlowPoke
Replied by SlowPoke on topic Re:Just got a new project
Hey. Bruce here from Canada. I have some thoughts on painting your frame if you still need them. I have prepped and painted uncountable bike frames and have a process that seems to work well and is not so labour intensive as you might think.
2018 Suzuki Vstrom 1000XT
2014 Yamaha Bolt
2009 Yamaha XT250
1977 Yamaha DT250
Hammond Organ
Fender Bass
2014 Yamaha Bolt
2009 Yamaha XT250
1977 Yamaha DT250
Hammond Organ
Fender Bass
08 Apr 2020 05:44
#35
- Godlygaz
Always interested in pointers!
I'll try to give back when I'm done too
Sent from my POCOPHONE F1 using Tapatalk
08 Apr 2020 06:28
#36
- 4oaks
- Big Dog Contributor
Replied by 4oaks on topic Re:Just got a new project
It looks like you have a flywheel puller which would work for non e-start flywheels, but unfortunately not your application. Take a look at this thread yamaha-enduros.com/index.php/forum/speci...rovised-work-arounds
It looks like folks typically use a slide hammer puller as the armature of electric start models can be a bear to remove.
If you take a look at the AT-1 service manual, Yamaha also indicates you can use a special armature puller bolt, which has a long pin on the end to push it off of the crank. This thread talks about how to make a makeshift system. 64.234.201.42/yamahasnitz/topic.asp?TOPIC_ID=10
Hope that helps!
Hope that helps!
Replied by MarkT on topic Re:Just got a new project
No picture attached... technically you don't have a flywheel... you need an "armature puller" which is just a long threaded bolt 10mm x 1.25 I think....
08 Apr 2020 07:12
#38
- Godlygaz
Blimey that is a special tool isn't it...... Sounds like I gotta cut the end off a 5mm Allen key and screw it down into the hole
08 Apr 2020 07:33
#39
Yamaha RD350 and RD400 use the same removal procedure... might search RD forums for ideas.
08 Apr 2020 08:54
#40
