Re:Just got a new project
- mdscott
Replied by mdscott on topic Re:Just got a new project
I had a similar problem with a CB750 tank, I ended up chipping away with a screwdriver and grinding with a Dremel tool. I was able to get all the Bondo off, but It was to bad of shape so ended covering it back up. The PO pulled out the bracket holding the badge and it left holes on the tank.
You Britts are so classy,
flowers on the table while working on the engine.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
26 Mar 2020 07:51
#11
- DEET
- Moderator
Replied by DEET on topic Just got a new project
Looks like someone didn't use the proper tool to disassemble the clutch.
26 Mar 2020 09:47
#12
- Godlygaz
Replied by Godlygaz on topic Re:Just got a new project
This is correct ... We are locked down in the UK so no where to buy one, gave it a go..... And a very bad decision that was.
The flowers made me happier thou
Sent from my POCOPHONE F1 using Tapatalk
The following user(s) Liked this Post: mdscott, Snglsmkr, JimA
26 Mar 2020 09:56
#13
- Schu
Replied by Schu on topic Re:Just got a new project
I will give blasting a try. I have access to a really nice blasting cabinet and never gave that a thought.
26 Mar 2020 10:41
#14
Replied by MarkT on topic Re:Just got a new project
Yup. You have the 12 volt starter/generator system..
It requires a 12 volt battery and requires a good battery to make spark for the ignition.
(The magneto models are 6 volt and don't require a battery for spark)
26 Mar 2020 11:08
#15
- Rick C.
Replied by Rick C. on topic Re:Just got a new project
Paint stripper works wonders for softening the filler, but you will have to re paint the tank.
26 Mar 2020 11:27
#16
- Godlygaz
Hi all
So I was going to get the frame etc sand blasted however as you might expect I can get this service done because everywhere is on lock down.
Are there any other options? Essentially I just want the frame super clean so I can prime and repaint, I don't think there is really anything wrong with it away from that
27 Mar 2020 03:34
#17
- Pedalcrazy
Replied by Pedalcrazy on topic Re:Just got a new project
Paint stripper will soften it enough but will need several coats, let sit, scrape out and repeat. That will work .
27 Mar 2020 08:02
#18
- Godlygaz
On this , as I am stuck in limbo on the project, I have taken to trying to fig out the Bondi with nail varnish remover! A.k.a slightly watered down acetone.
I'm finding that coating a tissue in the stuff and then cling filming it to the tank seems to be working, but I have yet to see if it will truly work!!
The following user(s) Liked this Post: KennyV, Schu
27 Mar 2020 09:12
#19
- darinm
Replied by darinm on topic Re:Just got a new project
Can't say I have a lot of experience removing Bondo but it seems like a wire wheel in a cordless drill might do the trick?
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
27 Mar 2020 11:17
#20
