XT 250 Sluggish
Replied by MarkT on topic XT 250 Sluggish
I wish I had a manual that would maybe show the operation better. I suppose Yamaha could could have used two pick-up coils or something but I've never seen that done.
26 Mar 2025 14:10
#41
- Catpie
Replied by Catpie on topic XT 250 Sluggish
I will try the fix in the video , if it dont go well ive lost nothing
. Will keep ya posted how it goes.
Triumph Bonneville TT100
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
26 Mar 2025 14:12
#42
I found some info on a UK XT250 from that era... diagrams show the basic two-wire source coil and two-wire pickup coil so nothing that appears it has a separate sensor for the advance. www.scribd.com/doc/95729057/Repair-XT250-Yamaha-1980-1983
On the baking, use caution on the temp... especially he is using Farenheit and not Celsius/Centigrade scale. There are also many other methods... I think my friend mentioned starting with a lower temp like 200F (93C) for a longer time like an hour or two. And if that doesn't work he raises temp and shortens time.
Replied by RT325 on topic XT 250 Sluggish
Replying to a couple of pages back yes advancing is all magic in the box. It'd be real good if you can borrow a known good one to plug in. Only reason I say that is. When they blow & stay on retard you'd be struggling to get the revs past about 2000 & would just hold back & maybe spit back through the carb & try to blow the carb out of the manifold. I'm just thinking back to the few I've had at work a lifetime ago. I say all that because you said you can get revs but maybe I'm misunderstanding a little. Pulser coil needs about 30 thou feeler blade under it but as I recal experimenting once if the air gap is closed down its just slower to get to advance but still goes there. Hope I'm not making a pigs ear out of explaining things. So all cdi & stator plugs are original not substituted fir individual plugs? So can't go wrong connecting things. I know what I'd do but maybe better not. On one I moved the flywheel about 30 degrees & fitted it minus the key. Did it up super tight to prove a point and apart from expected kick back she ran perfect. So point proven--box not advancing. Haven't proof read so hope it's legible.
- Catpie
revs ok when im testing on the bike table but when taken out on the road & try and open it up it coughs & splutters , does pop a bit & is dog slow , i will test the gap between the pulser coil & flywheel & see what that shows . as far as im aware stator, CDI etc are all original .
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
26 Mar 2025 14:49
#45
Way back did you say the source coil had been rewound. Not sure I'm reading anything into that except I've got a suspicious nature lol. Like why was it rewound, no spark at all or chasing the fault were still chasing etc.
26 Mar 2025 14:59
#46
- Catpie
No it was not rewound but the wires were shot so i had it rewired & a new loom to match from REXs Speedshop
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
26 Mar 2025 15:02
#47
- Catpie
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
26 Mar 2025 15:22
#48
Ok, so the wires to the sourcy thing were rewired.
I'm sounding like a broken record i know.
So red is red & brown is brown?.
They come off each end of the ignition source coil.
Bike looks nice i must say.
Lets get it running nice. & you've mastered posting photos, Cool.
Just another random--i hate that word the grandies use--.
Is there a chance the source coil could be fitted flipped over end for end? if it was taken off for it to be rewired--not rewound. Mostly they cant be flipped but without a pic in front of me i'm guessing & flying blind.
26 Mar 2025 16:00
#49
- Catpie
Checked the source coil gap all ok then put the CDI in my parts oven for a roasting ,what i noticed was lots of little bubbles on the epoxy part as it warmed up ,put back on bike & i am amazed when revved it advanced towards the source coil , still got to road test it once all back together but so far so far so good. A very big thanks for all your help, will let you know how it goes. Regards
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
The following user(s) Liked this Post: MarkT, RT325, Swoop56, Ht1kid, Sneezles61, pahiker
27 Mar 2025 10:33
#50
