XT 250 Sluggish
- Catpie
Replied by Catpie on topic XT 250 Sluggish
Timing all lined up and checked , but although it runs it is still sluggish and now i think its a fuel problem with acceleration . Ticks over fine , & revs ok , bit hard to start & if you spray carb cleaner down the bore it will start straight away & idle but when ridden its is slow , popping & farting and running shite , i have sonic cleaned & rebuilt this carb checked for leaks , does anyone know of a compatible carb that will fit ( at least to try ) as XT carbs in the UK are rare & very expensive. Thanks
Triumph Bonneville TT100
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
23 Mar 2025 13:49
#11
Replied by RT325 on topic XT 250 Sluggish
I've forgotten what I said on this post but did I mention I've replaced cdi boxes on a few at work as blow the advance thingy in the box. If that was the case the header pipe would glow red in the dark & it would barely drag itself along. Only other thing is S I think I said or showed a pic of my inlet cam almost totally round with no lift. Or a low flying duck up the exhaust. I guess the exhaust could collapse inside & block it when powering on, like blowing stuff against the inside stopping exhaust gas getting out. Had that on a go-kart but muffler on the end fell to bits blocking it. OK I'm clutching at straws but I don't realy suspect carb well not yet anyway. See what others say. One more, any chance the flywheel key has broken. We love videos. Helps a lot.
Replied by MarkT on topic XT 250 Sluggish
My first thought was that old saying "90% of carburetor problems are electrical"... but just a gut feeling that CDI might be bad if you truly have gone through the carb well and checked everything out.
The following user(s) Liked this Post: Ht1kid, Oldbikenut
23 Mar 2025 15:41
#13
- Oldbikenut
Replied by Oldbikenut on topic XT 250 Sluggish
I think you’re on to something here, I fought and fought what I thought was carburetor issues on my 83 XT250, ended up switching out my CDI and all of a sudden everything was all good!
1971 RT1B-360
1971 Honda Trail 70
1972 Kawasaki S2 350
1975 Ossa MAR 350
1978 Honda Trail 90
1983 XT250
1984 Honda XR250R
1971 Honda Trail 70
1975 Ossa MAR 350
1978 Honda Trail 90
1983 XT250
1984 Honda XR250R
23 Mar 2025 17:07
#14
Another random thought wnhen we got the source coil rewound on one the guy rewound it back to front --or something. Man did that cause headaches lol.
But a phone call sorted it & said reverse the red & the brown.
That's probably something you'll never come across again.
But by memory the red & brown from the stator the colors fade bad & red & brown look similar.
If they go to a multi pug which i think they do--then cant realy go wrong.
Just keep any DC red battery power away from any cdi red or you'll know where the problem is--follow the smoke.
- Catpie
RT325 the stator was rewired & also a new loom all by Rexspeed shop so i dont think the problem is there but MarkT might be onto it so can i check if the CDI is bad as the manual states i need a Yamaha pocket tester !!!! to do it . Regards
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
24 Mar 2025 12:49
#16
Be real easy if you had a strobe light pointing at the flywheel to see if it's advancing. It moves through about 30 degrees so is a lot of movement to read on the outside of the flywheel. Strobe lights are cheap if you look on the right sites.
24 Mar 2025 15:39
#17
- Catpie
Hi , i have put a strobe on the flywheel & the F mark is spot on with the marking on the engine casing . I take it that is as it should be .
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
25 Mar 2025 10:45
#18
But what happens as you rev it? On a four stroke it must advance smoothly.
Also look for erratic flashing
25 Mar 2025 11:32
#19
- Catpie
I will have another go tomorrow and give it a good rev up , should the timing mark (F) stay on the mark or should it move . Thanks
Yamaha XT250
Honda CB450
Yamaha XT250
Honda CB450
25 Mar 2025 12:20
#20
