Does a DT1 gas tank fit on a DT2 frame?
- mpercy
Does a DT1 gas tank fit on a DT2 frame? was created by mpercy
I like the badge bike look so checking to see if it would fit. thanks
09 Aug 2026 09:33
- darinm
Replied by darinm on topic Does a DT1 gas tank fit on a DT2 frame?
They do on the CT1 to CT2, I'd guess it would be the same on the DT series.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
The following user(s) Liked this Post: mpercy
09 Aug 2026 10:21
Replied by RT325 on topic Does a DT1 gas tank fit on a DT2 frame?
There's a slight difference between frames but i cant remember which way when swapping tanks--like early to later or visa versa. The difference is where the subframe is welded to the top tube. Its all do-able but there's something there where back of the tank sits to be careful of.
09 Aug 2026 18:38
- Enduro nut
Replied by Enduro nut on topic Does a DT1 gas tank fit on a DT2 frame?
It might. I have a rat bike that's a 69 DT250 frame with a 72/73 DT250/RT360 tank on it. The seat comes down on top of the tank. The seats all beat up so i just use a piece of tube to dampen it and it works fine. The DT1 tank might be shorter and may yet work but the frames are definitely different.
- Mark350
Replied by Mark350 on topic Does a DT1 gas tank fit on a DT2 frame?
I used a RT2 tank on an RT1 frame, so the DT2 /DT1 tank fitment should be the same. The other way around should work too? Be advised though, one of the oil tank mounts are different, the rear lower frame tank mount pin is orientated differently but easily modified.
12 Aug 2026 19:27
