The Sachsaha
- Sachsaha
Replied by Sachsaha on topic The Sachsaha
Ive been working on the battery bracket. I started out making this
23 May 2019 04:47
#61
- Sachsaha
Then i added a bit to attach the vape regulator/rectifier.
Still working on the foot controls. The shifter is on but is too long. Im going to see if my local moto shop has anything that will work or i may have to cut down the stock one. Im almost done with the brake as well. Its hard when you dont have a welder at home and everything has to be taken to work, then back home to be fitted, then back to work for the next step, then back home....
23 May 2019 05:00
#62
- Sachsaha
Shift lever
The following user(s) Liked this Post: Badger52
12 Jun 2019 04:02
#63
- Sachsaha
Rear brake lever.
12 Jun 2019 04:05
#64
Replied by MarkT on topic The Sachsaha
Nice work!
12 Jun 2019 05:19
#65
- Sachsaha
Thanks!
12 Jun 2019 14:21
#66
- Sachsaha
Started my Vape/Power Dynamo install.
Coil is installed (no pic). Just have some wiring to do then i can try and start it a see if i got everthing right...
The following user(s) Liked this Post: ScottMalv, Pillsbury, KennyV
23 Jun 2019 08:00
#67
- Sachsaha
The bike is all back together again. I took it for its first ride on the road yesterday. Road it to work so i could build a rear brake switch bracket and weld the battery bracket on. Overall it did ok. I think the timing may be a bit advanced as there was a time or two i thought i heard some slight pinging and when starting the bike i got a kickback once or twice. Also forgot to put air in the tires.... i think the rear might have had 3-5psi and the front maybe 10! It was a bit of a squirrelly ride to work.
Also, i need recommendations on a new rear sprocket size. That 56 tooth one is awsome on a tight trail but it seems to limit my road speed a bit.... the shop manual says stock is 15 front and 44 rear with 18 by 4.00 tire. I have a 19 by 3.5 tire and a 15 front sprocket. What are you folks running for a more trail oriented bike? It would be nice to be able to do 65 on the hwy at a fuel efficient rpm (what is a fuel efficient rpm for hwy speeds?). Can a guy have both? What is a good compromise?
Jonathan
Jonathan
28 Jun 2019 05:23
#68
- Sachsaha
Checked the oil injection pump adjustment. It all seems to be in specs. Is there some kind of a flow test i should do or should i trust that its functioning properly and start putting straight gas in the tank? After this riding season is over i will have deet rebuild it so i wont have to think much about it again but it would be nice to not mix gas it i dont have to.
30 Jun 2019 06:25
#69
- Mothersbaugh
Replied by Mothersbaugh on topic The Sachsaha
Flow test would be in the manual in the tech library...
30 Jun 2019 07:16
#70
