69 CT1 Clean Up
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 69 CT1 Clean Up
Looks like the rear shocks have seen better days. They are in the ultrasonic right now, but don't think that is going to help alot.
Length fully extended: 12" (305mm) center of eyelet to eyelet
Mounting holes: 10mm
Mounting hole depth: 20mm
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
23 Feb 2026 21:47 #21
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Added oil to shocks, cleaned them up. They need replacement. Hopefully they will work fora while. Ended up with 50ml in each and some short term repairs. Need to find the steel compression rings.
Front forks had about 90ml each of fork fluid. I almost want to replace the seals since I'm that far in.
going to assemble rear shocks as is, then replace when I find a good pair.
a 1.25mm and 0.75mm over cylinder, both CT1, piston port cylinders. I originally intended to build the 2nd engine I have, not sure if I will or not at this point. I'm going to have to replace the case halves and L/R covers and bearings not a bad idea.
some of the clean up went well. levers are the ones on bike.  I have 2 that I will be replacing them with.  They have provisions for mirrors and
a clip in brake switch.  Essentialy same ones as my DT360.  The left hi/lo beam will get replaced with what I think may be something from a later CT1 or RT.
An alum, L/R turn signal sw/ w/ horn.  They goal there is I will have turn signals on this one as I plan to get it approved for street use.  I probably don't need them to get approved, but the original harness has provisions for turn signals.
Looking forward to a fresh clean frame to start building on.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 25 Feb 2026 21:11 by pabdt.
25 Feb 2026 21:05 #22
Replied by Phyllo on topic 69 CT1 Clean Up
Hey PABDT, I've had a few Enduros over the years, and currently have a DT-3. I was never aware that you could replace or even access fluid in the shocks. Would you be able to provide a quick explanation how that's done?
THanks and your restore is coming along nicely - great work!
The following user(s) Liked this Post: MarkT, Snglsmkr, pabdt, Ht1kid
26 Feb 2026 05:21 #23
Replied by Snglsmkr on topic 69 CT1 Clean Up
I was desperate to increase the dampening on my CT-3 shocks in the 70s prior to a Hare-n-Hound. I drilled a small hole through the side of the reservoir (because I couldn't see a way to disassemble them) to let the old fluid out. Then a friend welded hex nuts on the shock body centered with the hole. Two very short pan head screws with plastic washers were used as plugs. I recall the first replacement fluid I used was hypoid gear oil. I was convinced I needed a much thicker fluid to get noticeably stronger rebound damping. I'm here to report the shocks returned in slow motion!
The following user(s) Liked this Post: MarkT, RT325, pabdt, Ht1kid
26 Feb 2026 11:48 #24
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Note, these shocks are untested. They were filled based on estimates I made.
Attached is a video of how I removed the springs. Made from 2 threaded rods and a some stock I had in garage. Obviously, there are different ways to do this. I saw a video recently where a guy used a sprocket and some eye bolts to easily compress the spring. I liked that--may make a tool like this. The video below is of a DT360 shock, but the shock springs install the same way.
To open the shocks and inspect the internal components, simply do the following:
1. remove spring, heat the spanner cap with a torch a few seconds. Sometimes the factory notches the tube so it won't loosen, so round that out first where the spanner tool inserts. These caps are tough to remove, hint some heat is nice.
2. Use a hardened steel spanner tool and remove the cap. I believe I used a 3 or 4mm tool.
At that point you can remove and inspect the components.
These shocks have 2 basic cylindrical containers. The inner tube has holes in the bottom to allow a prescribed rate of fluid movement for compression. When you compress the shock, the fluid ends up in the outside compartment. On rebound, it gets vacuumed back into the inner tube.
Remember when adding shock fluid, for most part the air compresses in the shock, not the shock fluid. If you top off the shock full, no air, it will hydraulic lock. No rebound or compression! Once you add fluid to the shock, let it sit for a while with air side up, so the bubbles can rise out of the fluid. If you fill it to a point that it is starting to get slow to expand or compress, you are probably close.
If you don't need to inspect the internal part of the shock, do what snglsmkr did and just drill and tap a screw. Don't worry about hitting things internally w/drill, there is quite a gap between the inner and outer compartments. Then you can add small portions and just test.
Hopefully this answers your question. I don't have any pics of the disassembly, as I did it fairly fast.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 26 Feb 2026 15:32 by pabdt.
26 Feb 2026 14:32 #25
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Fuel Valve Rebuild. Was glad I took it apart. Full of everything but fuel. The gasket has dried and broke off blocking I believe the reserve fuel supply.
KDI Repros Fuel Petcock Rebuild Kit.   I usually lube the rubber gasket with synthetic brake grease from oreillys.
gasket tore and blocked fuel exit.  Tank actually looks good inside.
got to flip handle other direction.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, Schu, Ht1kid, pahiker
04 Mar 2026 21:54 #26
Replied by Lizeec on topic 69 CT1 Clean Up
Hi PABDT
There is a thread on here somewhere (I couldn’t find it) on new genuine Yamaha fuel petcocks with part numbers that will fit our bikes the different part numbers are for petcocks that have downward & 90* left and right fuel exit nipples.
The reason I posted this for some reason all the ones I use to rebuild with even genuine parts would have about a 50% success rate of working and not leaking eventually, the new part number ones are originally found I think on four wheelers and may look a little different but bolt up the same, I think on some applications I had to shorten the fuel pipe that goes into the tank, so if originality is your goal these may not be for you. They were or used to be around $30? So it was very minimally more than buying the rebuild kits or Individual parts from Yamaha but in the end you have a brand new genuine Yamaha petcock, I would stay away from the cheap eBay copies as they just usually cause more issues.
Maybe MarkT can locate the thread if it has been archived?
Last edit: 05 Mar 2026 08:04 by Lizeec.
05 Mar 2026 07:59 #27
Thanks for the explainer on how you did the shocks.
05 Mar 2026 10:21 #28
Replied by MarkT on topic 69 CT1 Clean Up
Not archived.  yamaha-enduros.com/index.php/forums/perf...s-for-our-bikes#1052
I think there have been a few threads on this topic, so maybe a different one was searched for.
The following user(s) Liked this Post: pabdt, Schu
05 Mar 2026 12:19 #29
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
appreciate link and info. If this one doesn't seal, I'll have to check that out.
Speaking of Quads. I went to start my wife's yesterday, fuel poured from the outlet when I turned petcock on.
...ah more work to do.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 05 Mar 2026 14:02 by pabdt.
05 Mar 2026 14:01 #30
