69 CT1 Clean Up
- Lizeec
Replied by Lizeec on topic 69 CT1 Clean Up
Thanks MarkT for finding the thread
05 Mar 2026 16:33
#31
- goatboy56
Replied by goatboy56 on topic 69 CT1 Clean Up
I have been using 3JN-24500-10-00 and you have to shorten the fill tube. I pull off the plastic filter and cut tube down and then cut a groove part ways thru below the cut and use a hot pin to melt a point into the groove to hold filter on. I always use new screws and washers.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
05 Mar 2026 18:13
#32
Replied by RT325 on topic 69 CT1 Clean Up
#24, yep i did that too & got them so slow returning they were pretty much still compressed when i hit the next bump haha. I also used Hypoid EP90 in my DT1 gearbox for motocross after destroying 3rd gear big wheel which was a weak gear in the coarse tooth very early gearboxes. Broke into 3 & came out the bottom. So thought i'll cushion it as much as i could. Worked good & clutch didn't suffer except on a cold day first use.
That reminds me--my old Vauxhal Car was so stuffed that i tried hypoid ep90 in the motor & stunk the village out haha. That was a fail & couldn't go anywhere as everyone new where i was.
- pabdt
Replied by pabdt on topic 69 CT1 Clean Up
seat day. more to do here. did a light blast of seat to keep as much of original paint as possible.
the tape was a give away...
previous repairs.
1st coat thin to set a good strong base. all gloss black on bike will get Eastwood's Extreme Chassis Gloss Black
previous repairs.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- pabdt
looking better than I started and all rust blasted away before paint.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
15 Mar 2026 13:47
#35
- pabdt
Was working on forks. Finally got my o-rings and seals in. I don't really like to blast these to keep particles out of the tubes, but after applying paint stripper, a maroon or brownish looking color emerged.
When I got the bike, it had white forks. I know that was a repaint. After applying paint stripper, found a brownish/maroon looking coat. Now wondering if that was a repaint. Going to careful delayer my way down. Seems this CT1 has more history to reveal. They will likely end up brushed alum.
Were the orig forks alum/gray like the engine covers?
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Replied by MarkT on topic 69 CT1 Clean Up
69 would have steel fork lowers if I remember correctly? Painted silver.
The following user(s) Liked this Post: Snglsmkr, pabdt
15 Mar 2026 17:12
#37
- pabdt
Interesting. I looked again and they are steel, but see no silver paint layer. white -> maroon -> steel. Going to look closer for traces of silver. I think maybe they were stripped for the first repaint. Looks like I'll be painting them.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
15 Mar 2026 18:46
#38
- Reed valve Richards
Replied by Reed valve Richards on topic 69 CT1 Clean Up
PABT nice to see you getting your bikes dirty and well done for wearing out a tyre, looks like quite a lot of tred was used up there!
Yo Joe, Go Joe
16 Mar 2026 01:57
#39
- pabdt
Forks have cleaned up well and look like they are in good shape. No rust or damage I can see.
Note to those who are not familiar w/these (me before this one):
To UNSCREW the seal housing, lightly heat the threads and put the axle housing in vice to keep it from twisting.
I used tire tube pieces to help protect it from the vice and tools to unscrew the seal housing. I was careful using channel
locks, but I suppose a strap would have worked better to protect it.
Are the forks the same color as fender?
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
19 Mar 2026 16:28
#40
