69 CT1 Clean Up
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 69 CT1 Clean Up
Thank you Mark. Yes, thats it. Also, it won't let me edit the post. When editing, I get a blank blox of data to edit. I'll leave well enough alone! Thanks again.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
29 May 2026 16:27 #61
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Well, batter up. Tank is next. Going to be challenging for me as I usually use vinyl stripes. This time, they get painted on.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
29 May 2026 22:44 #62
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Sneek preview of new paint.  Lots more pics to come after paint dries a bit.
Process:
* tank painted 2 base coats White
* stripes were then back-masked after 30 minutes w/ 5.5mm 3M Fine Line tape
* 2 base coats of Calif Orange
* 2 top coats Clear.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: Snglsmkr, Schu, Ht1kid, pahiker
Last edit: 30 May 2026 15:33 by pabdt.
30 May 2026 15:33 #63
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Few more pics from today.
I just realized I didn't check to see if the sticker on the oil tank was the right one. I was more dialed to alignment. Hopefully, I aligned it at the correct point. The decal is under the clear coat and the stripes are painted on like I did the tank. I added the over-spray on back like the factory did to the oil tank.
cleaned up parts, gave them a shot of Transtar 4603 here and there where metal was exposed, sanded lightly w/600, then same as above. 2 coats base, 2 coats clear.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: swm, Schu, Ht1kid, pahiker
Last edit: 30 May 2026 19:41 by pabdt.
30 May 2026 18:44 #64
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
This "looks" like a good idea, but in reality I blew over-spray through the holes when I painted the inside. I probably won't do it again. Lucky, I caught it right away and just laid another layer over the backside of the bucket.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 30 May 2026 19:39 by pabdt.
30 May 2026 19:36 #65
Replied by Snglsmkr on topic 69 CT1 Clean Up
This is an extensive "clean up"! Its looking great. Thanks for sharing your progress.
01 Jun 2026 20:24 #66
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Once day I'm cleaning it up, the next day I'm looking at a stripped frame in garage. lmao.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
02 Jun 2026 17:54 #67
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
A sneek preview from today. several unfinished items (fuel, wiring, etc) , but getting closer to a start up. Oops forgot to reroute that throttle cable before pic.  oh well.
problem:
* key switch.
while looking for a switch, wired everything up for position #2 w/kill switch to be mounted on bar.
Start up hopefully Fri.
I'm going to try something I have not before, when done, going to add a youtube video of the "clean up" w/sound clips for those who
are unable to access via imgur.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 03 Jun 2026 16:17 by pabdt.
03 Jun 2026 16:16 #68
Replied by MarkT on topic 69 CT1 Clean Up
Are you missing the key switch completely?
03 Jun 2026 17:15 #69
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
I “had” a switch.   I think I saved the case.  I may be able to scrap together what was in there.  I got p/o got the wire cutters out, added a few 4mm butt connectors where sw used to be.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 03 Jun 2026 19:05 by pabdt.
03 Jun 2026 18:59 #70
