Who is the DT2 ENGINE GURU that has time to talk?
- MACKAY
Who is the DT2 ENGINE GURU that has time to talk? was created by MACKAY
I am confused on the connection rods and piston options for a 1972 DT2 250... Is there anyone out there that is will to spend some time talking about the options ?
25 Jan 2022 15:57
Replied by Gr8uncleal on topic Who is the DT2 ENGINE GURU that has time to talk?
Are you looking for help on the actual mechanics side, or possible inconsistencies in the online parts manuals?
25 Jan 2022 23:47
Replied by RT325 on topic Who is the DT2 ENGINE GURU that has time to talk?
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=154442447662&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Is yours 130mm centre to centre
26 Jan 2022 02:14
- MACKAY
Replied by MACKAY on topic Who is the DT2 ENGINE GURU that has time to talk?
I am looking for a piston kit for my 1972 DT2 250 Engine number DT1-F133299 reed valve engine. The stock bore & stroke is 70mm x 64mm I have a couple of spare jugs but they need to be bored. I have a couple of options, One jug can be bored out to 71mm and the other can be bored to 71.5mm, After tons of time calling and searching I am unable to find a pistons kit that meets my needs of the 71mm & 71.5mm reed vakve dyke ring piston kit.
Has anyone else ran into this problem and if so what did you do to resole the problem?
I also have a good crankshaft with a # 214 360cc connecting rod that is 5mm longer than the stock #311 250 rod, are there any options to using that rod with a mx piston kit ?
Thank you
Thank you
26 Jan 2022 13:32
If you're completely stuck could you make a base plate to lift the cylinder 5mm. I/ve done similar on my DT1 piston port motor but that's due to running a 360 70mm stroke crank--6mm increase stroke which was probably a 5mm plate & gasket either side to make 6mm. Anyway that's another story from long ago.
26 Jan 2022 13:56
- MACKAY
I have a good 311 rod so that's not the big problem, my major set back is not being able to locate a 71 or 71.5mm reed valve / dyke ring piston set... If there was a piston that would work withe the 214 rod I would switch the rods. Just trying to find a piston kit
Thanks for the reply
26 Jan 2022 14:10
- yamayeeha
Replied by yamayeeha on topic Who is the DT2 ENGINE GURU that has time to talk?
I believe the YZ250A piston ran with the 214 rod. Piston pin height to match that rod. I think Wiseco #398 would work. I bought a #398 and the pin height was to match the 214 rod - only problem is I am going from memory so it would be best to confirm this. Also maybe the Wiseco #230 is also the same - I have this in my notes but can't confirm this.
26 Jan 2022 14:37
Dykes top ring isn't important. There will be plenty of 71.5 aftermarket kits for YZ's from the early years but need to know the pin height to top of the piston & they mostly don't list 'that' measurement. I'm guessing the likes of DT250 up to "79 would work & YZ's in the mid "70's. Just google Yamaha 71.5 piston kits bit weed out the two strokes from 4 strokes. Hopefully them that know will be along before i lead you astray. Did like my DT2 though, back in "72.
26 Jan 2022 14:42
Replied by MarkT on topic Who is the DT2 ENGINE GURU that has time to talk?
Have you reached out to Enduronut for a piston/rings? He often has them.
26 Jan 2022 15:46
