Holy Piston Batman.
- Tinkicker
Replied by Tinkicker on topic Holy Piston Batman.
Apropos earlier in the thread. I was slinking around in the machine shop and saw one of the lads fastening a bearing track into a lathe. Interest piqued, I wandered over, wiped my nose on my sleeve and said "watcha dooin".
Apparently the grinder had broke down and he was using one of the lathes to make a special fillet on a bearing.
I thought it would be good to take some pics to show how it is done. You cannot see anything in the grinder as the bearing to be copied is loaded in and the grinder copies it. Nothing to photograph. All behind guards.
Unforunately in my case, the grinder cannot add metal.....
Bearing to be copied is a special bearing for a Clarke transmission. It fits on a heavily filleted shaft and needs a special internal profile to fit against it. Cost of this bearing from Clarke is over £300.
Basic ISO bearing is about £60. No brainer, they do a batch of about 20 at a time.
The lathe method is same as the grinder method, only the grinder copies the bearing profile itself directly from the original bearing and the lathe needs the machinist to make a profile template. They use a laser scanner (cardboard and scissors in the old days) to get the profile and input the coordinates into a laser cutter to cut out the profile for the lathe. Usually the cutter is used to make gaskets.
Profile of required fillet made and fitted into lathe. The arm follows the profile and controls the cut. It is actually a mirror image of the required cut.
Bearing getting whizzed around in the lathe. The cutting tool needs to be upside down and the lathe is actually in reverse. No coolant used for some reason, and the sparks were pretty impressive. Did not turn out well on the pic.
£60 bearing turned into a £300 one.
The following user(s) Liked this Post: MarkT, RT325, Snglsmkr, Ht1kid, LongStride, Sneezles61, Paul@PJME, pahiker
- Tinkicker
To purloin a phrase from Motley Crue.. Kickstart my Heart.
Carb on, exhaust on, wiring connected, fuel tank plopped on. Fuel feed connected. Autolube pump bled.
Ignition on. Kick. Kick ring a ding ding.
Ran it long enough to set idle and check autolube pump was stroking. It was.
Pulled back the pulley to observe max pump stroke output. Looked like it should from what I remembered from last time I checked this un and the 100 output. Since I never disturbed the pump or any adjustments, and it is stroking, I will call that ok. I have no premixed fuel to run it long enough to measure output and I do not want to idle it for a few minutes with just the build lube inside. Injection pipe refitted and let it warm up for five minutes.
Sounds good and has six in the box.
Just need to fit the carb vent pipework, button down the tank, refit the oil pump cover and generator cover, and she is pretty much ready for a gentle road test. Piston rings have already been heat cycled and bedded in.
It was pretty smoky in there as the build oil was burned off.
The following user(s) Liked this Post: MarkT, RT325, Ht1kid, LongStride, Sneezles61, cranky_dave, pahiker
- Tinkicker
Road test time. Took her out on a run arround the village perimeter. Probably around three miles.
She pulls fairly strongly through the gears and behaved impeccably.
She feels different somehow, more refined. Perhaps now the carb has been put back to stock settings and with genuine parts, the carburation is right.
Although I have not taken her above 5000rpm yet, I can still detect that vibration through the pegs at 5000rpm, but I had a notion as to what it could be over the winter.
I think it is the chain running over the new nylon chain tensioner block. It has not yet worn enough to allow the chain rollers to glide across it and I am feeling the edges of the sideplates hitting the edge and sliding over the block.
The tensioner arm is bolted to the same frame crossmember that the pegs are fastened to....
Back where she belongs.. On a very chilly day. My nose has not stopped running yet..
The following user(s) Liked this Post: MarkT, Snglsmkr, Schu, Ht1kid, LongStride, Sneezles61, Paul@PJME, pahiker
28 Jan 2024 03:46
#93
- Sneezles61
Replied by Sneezles61 on topic Holy Piston Batman.
So the demon has been exorcised?
Sneezles61
Sneezles61
28 Jan 2024 05:45
#94
- Tinkicker
Hope so. Before I take it on a longer run with high throttle settings in warmer weather, I am going to buy myself a CHT gauge to see how high it goes at WOT.
28 Jan 2024 07:20
#95
- Tinkicker
Finally got around to fitting CHT gauge. Best looking and easiest way without making a permanent alteration to the bike was to simply cable tie it to the clutch cable where it is supported by the handlebar and chest protector.
High temp alarm is set to a conservative 196C (385F) so a bit of headroom to account for gauge lag. Apparently it flashes red when max temp is exceeded and the temp numbers flash also.
It will be nice to know how hot she runs at various throttle positions. Since I fitted the genuine #130 main as per UK spec, I must admit the plug is a very nice dark tan colour.
The gauge unit has no means to be switched off which is odd, but at least the CR2032 battery is easily replaced and the temp reading seems accurate as when I first activated it in the living room, it agreed with the heating thermostat readout.
Hopefully no more blown pistons.
The following user(s) Liked this Post: MarkT, Snglsmkr, Schu, Ht1kid, Sneezles61
- automan
Replied by automan on topic Holy Piston Batman.
That ain't a gonna react fast enough to prevent a holy piston.
Kind of cool to see plug/head temps though.
cliff
cliff
31 May 2024 12:22
#97
- Tinkicker
Yeah. I already know what blew the last piston. I went too lean on the cheapo main and got caught out when the tank went onto reserve. In addition i had a "splash" of two stroke in the oil which did not help.
With this temporary instrumentation, at least I will know how long to hold the throttle open before hitting the danger zone.
However, now I have stock OEM jetting, I do not anticipate a problem.
31 May 2024 15:24
#98
- Reed valve Richards
Replied by Reed valve Richards on topic Holy Piston Batman.
Great to see this bike back on the lanes. Don't see too many of the blue or green one's for that matter. I think the yellow one was the most popular.
Yo Joe, Go Joe
31 May 2024 19:22
#99
- Tinkicker
Took her out this morning for a 30 mile ride to observe the CHT.
Outside air temp 16C.
Town and village work at 30mph, 5th gear and 3500rpm saw her fairly steady between 155 - 160C.
The max I saw on the open road with wide open throttle for several miles was 185C. A bit below the 195C I set as the alarm temp. Of course she will run hotter in warmer weather.
More usually at open road speeds with a little mechanical sympathy, with throttle not pegged against the stop, the temp was low to mid 170s. I did see it climb to 178C once but only for a couple of seconds.
The head is a large chunk of metal that takes a lot of energy to heat up and a lot to shed to cool down, so as Mark T says, it is important to realise that the piston heats up far quicker and runs far hotter than the gauge would suggest, so keeping a healthy overhead is important.
Very pleased with the way the bike is running, very crisp off the throttle in the lower gears, but a tad overgeared in the uppers. I am thinking of putting her back to stock gearing.
I think she will be far happier on stock gearing and will see a higher top speed. At the moment she is faster in 5th than 6th.
The other takeaway from this is that I intend to keep her and ride her. That is what I built her for, not as a show bike.
It may devalue her, but the market has softened considerably from when she was appraised.
I only had her professionally appraised for insurance purposes in any case.
The following user(s) Liked this Post: Swoop56, Ht1kid, Sneezles61
