Stator flywheel arching, any ideas?? 1975 Dt400b
  • TennesseeVol51
  • TennesseeVol51's Avatar Topic Author
Stator flywheel arching, any ideas?? 1975 Dt400b was created by TennesseeVol51
YouTube Video explaining my issues. Appreciate the help
17 Jun 2026 22:58 #1
Blimey, now I've seen it all, if it is arcing. Thanks for posting. Engine mount bolts tight. I've got no idea.
The following user(s) Liked this Post: TennesseeVol51
18 Jun 2026 15:05 #2
  • TennesseeVol51
Replied by TennesseeVol51 on topic Stator flywheel arching, any ideas?? 1975 Dt400b
I have no idea either
there was a lot of white dust in the mag cover. Which I assume is the rot of the magnesium cover and I’m thinking the electrical from the rotor was causing the magnesium to ignite and then sticking to the flywheel?? I think if I’m not mistaken wasn’t there some sort of a grenade in Vietnam that was magnesium?
maybe someone else can chime in with some information
18 Jun 2026 17:48 #3
Spray the inside of the cover with Gibbs Lubricant.  It stops magnesium corrosion and can be painted over.
gibbsbrandlubricant.com/shop/
I've never seen that kind of marks on a flywheel.  Almost looks like someone set it across battery terminals?  (Maybe they were trying to remagnetize or something?  LOL)
The evidence of water is why I've learned to remove both the oil pump and ignition covers after washing bike or riding in the wet.  Very common way for oil pumps and ignitions to get messed up.
The following user(s) Liked this Post: DVM, TennesseeVol51
18 Jun 2026 18:15 #4
Remove the rotor and clean everything thoroughly . It is very easy for the ignition pulser coil to be damaged with corrosion crud .
18 Jun 2026 18:26 #5
  • TennesseeVol51
Man I appreciate the help and support and I will order the Gibbs lube it really looks interesting to me.
I love trying new stuff like that!
18 Jun 2026 18:44 #6
  • TennesseeVol51
Here is a up close still picture I posted to Imgur
imgur.com/gallery/1975-dt400b-flywheel-2UZzw6I
18 Jun 2026 18:51 #7
If that one was welded maybe for balance or some other reason, it could be brittle and of course you
wouldn't want it to fly apart. if you decide to get another, saw a used one on ebay $65. Of course, you have to figure out what is going on.
Here is a new one too across the pond. These guys have all the good stuff.
FOTO2173. www.cmsnl.com/products/rotor-assy_oc-0001-1518/
It is theoretically possible, you have a hydrogen fire burning in there when water is present.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 18 Jun 2026 22:15 by pabdt.
18 Jun 2026 22:01 #8
There's no sourcing going on on there unlike the minor sparks from a points mag. Expanding the photo I can see weld spots so wonder I'd someone was trying to get the flywheel off & tried welding a puller plate to the face of it. Wouldn't have been strong enough with just a spot of weld. Or welding a weight to it for more inertia. Unlikely all of those thoughts.
18 Jun 2026 22:30 #9
  • TennesseeVol51
I think you’re right Rt325 you can see the little balls of slag from stick weld. It really does look like someone welded a plate to remove the flywheel
18 Jun 2026 23:02 #10
