Holy Piston Batman.
Replied by Ht1kid on topic Holy Piston Batman.
TK glad you enjoyed your ride today with both of your bikes
01 Jun 2024 09:21 #101
  • Tinkicker
Replied by Tinkicker on topic Holy Piston Batman.
Swapped the #130 main for a #135 main this morning and gave her another outing.  Previous general CHT was upper 170s.
Air temp 16C.
With the 135 fitted, general temp was upper 150s to mid 160s.
Air Temp 26C.  Highest I saw at WOT for three miles or so was 172C and did not rise further.  Is this fairly typical?
The new jet has no made any appreciable difference in power or top speed, but the cylinder temps are appreciably lower.
One thing I have noticed is that a slight misfire it had in the lower gears at 4000 rpm on a steady throttle (around 1/8th) is a bit more pronounced since the jet change. The misfire is throttle position related as in the higher gears at 4000 rpm, more speed equals more drag and more throttle required and no misfire.
Similarly, in the lower gears, if the throttle is decreased, or increased, the misfire immediately goes away. It is only on a steady throttle it occurs.
I am thinking it is not transitioning smoothly from pilot to needle and has a flat spot.  But which is causing it?
Pilot should be #25 according to parts book and needle is on center groove.  Not sure which way to go.  Bigger pilot to richen or drop the needle to lean her a bit.
Otherwise she continues to behave herself and will hold a 1200 rpm idle all day long.
Oh and I think the speedo is under reading.  Need to check that.  Usual average speed for traffic on the surrounding roads is 55mph, yet I am keeping up.with them at an indicated 48 - 50 mph.
Last edit: 20 Jul 2024 09:22 by Tinkicker.
20 Jul 2024 09:16 #102
Replied by Gr8uncleal on topic Holy Piston Batman.
"Oh and I think the speedo is under reading.  Need to check that.  Usual average speed for traffic on the surrounding roads is 55mph, yet I am keeping up.with them at an indicated 48 - 50 mph."
Does any village near you have one of those signs that shows your speed as you approach it? Assuming they are accurate, you could approach one and compare the speed indicated on the sign vs your speedo.
20 Jul 2024 10:12 #103
Replied by msavitt on topic Holy Piston Batman.
Congratulations on a great outcome!
Ive been through a holy piston saga with my DT360 a few years ago and know the feeling when things go fro very smooth and joyful (and too lean) to oh shit no compression and am I going to have a heart attack or a stroke pushing this thing home!
20 Jul 2024 12:48 #104
Replied by RT325 on topic Holy Piston Batman.
TK post 102 would a leaner slide help, like a 3 instead of 2.5 for instance.
20 Jul 2024 14:25 #105
  • Tinkicker
No idea.  I can take a pile of 60 tonnes of obsolete rusty scrap  and turn into a fully functioning drag line excavator again, but carbs.  Nope that is black magic.
Even in my motorcycle tech years, it was about machine safety, availability and bums on seats.  Never fine tuning.
In that regard I am out of my depth....
20 Jul 2024 15:27 #106
Replied by crashMoped on topic Holy Piston Batman.
I did not write that. ∆
27 Oct 2025 17:22 #107
Replied by MarkT on topic Holy Piston Batman.
Not sure what you didn't write but I suspect you came across a post from a member who is no longer here.  The site software will show the name of whoever is logged in viewing as well as marking it as a "guest" post.
Confusing, but nothing to be concerned about.
27 Oct 2025 17:42 #108
I see, thanks for the heads up.
27 Oct 2025 17:46 #109
Replied by automan on topic Holy Piston Batman.
PJ-pilot jet and CA-slide overlap like you said.
1/8th throttle regardless of RPM is pilot jet or PJ screw.
cliff
29 Oct 2025 12:20 #110
