DT175MX // Porting advice?se
  • davidivjak
  • davidivjak's Avatar Topic Author
DT175MX // Porting advice?se was created by davidivjak
Hi everyone,
I am planning to modify my DT175MX ('81) a little, here's the setup I am going for:
- BigOne expansion chamber + silencer (already fitted)
- 28mm Mikuni flat slide (VM28-418, already fitted)
- allowing more air coming through the airbox (bought a cover that already had holes in it - so I am not destroying a stock one)
- VForce 3 reed valve with glass fibre reeds
- cylinder porting
I've got questions especially on the last point: I've never done porting by myself, but I am really keen to give it a try. Of course I will clean all the ports and try to improve the flow, for example by opening the boost port fully. Other than that I don't really have an idea what to do, so I would like to ask if anybody has done porting a DT cylinder and could give me some hints. I don't want anything crazy to squeeze the last bit of power out of it, just a gentle porting to fit the power band of the BigOne exhaust a bit more, which clearly likes higher rpms than the stock pipe. I think I would not touch the intake window itself, but would like to do some work on the exhaust and transfer ports.
I got myself a Clymer "How to" performance manual for Yamaha piston port models to '76 and found some port maps in it for 175cc enduro, motocross and motocross special. Is that something I can use as a guide?
Really appreciate any help! Thanks!
Cheers,
David
'81 DT175MX | '72 R5F | '82 RD350LC | '79 IT175F | '74 MX175A | '78 YZ125E
11 Jan 2026 06:23 #1
Replied by automan on topic DT175MX // Porting advice?se
"Mikuni flat slide (VM28-418, already fitted) "
VM's are round slides.
11 Jan 2026 07:48 #2
The exhaust pipe should be enough.
Leave the porting alone.
11 Jan 2026 07:49 #3
  • davidivjak
Replied by davidivjak on topic DT175MX // Porting advice?se
Yes, except for the 28mm from the TM series.
I don't know why they chose to label it as VM28.
Last edit: 11 Jan 2026 08:35 by davidivjak.
11 Jan 2026 08:34 #4
Cauz they do not know.......
11 Jan 2026 08:40 #5
Replied by MarkT on topic DT175MX // Porting advice?se
I don't have time to answer in detail right now but here is some info from one some of my previous posts here that you might find helpful for your projects.
While it will almost certainly run afterwards, messing with porting can very quickly give you less power than stock.  Do your research first and have the right tools, especially for the transfers!  Most people should probably consult an experienced professional with proven results on that engine and let them do the work.  Removing obvious casting flaws (which is rarely needed on a Yamaha) is ok, but altering port heights and sizes can really make a mess.  Just one mm change in porting heights can make a few HP difference, and if you're guessing, usually you end up with less power, not more.
One trick I often used was to analyze the pipe design first and then match the porting to optimize the pipe design. V Force is a waste of money on these old bikes in my experience, stock reeds work great. Every time I tried VForce, power went down, not up.
If you are "going wild" on the exhaust port, compression will be too low.  Cheapest fix for the monoshock DT175 is to fit a 77-79 IT175 head.  (Head bolts right on, IT175 cylinder will NOT)
I used Gordon Jenning's "Two Stroke Tuner's Handbook" to build my race engines... copy in the Tech Library here or on the Internet... still have the "real" copy I got in 1975.
A. Graham Bell also wrote some good books... still in print... some are probably available for download somewhere on the Internet
.......be careful of ring locator pin placement... using an IT or YZ piston can sometimes result in the ring gap passing over a transfer port if the pin spacing isn't right... very bad if a ring end catches in the port opening and it probably would eventually. Ring gap locations for various pistons marked in photo below.
Good luck with your project.
The following user(s) Liked this Post: swm, DVM, Schu, Ht1kid
11 Jan 2026 09:02 #6
  • davidivjak
Thanks Mark for your helpful answer!
I am quite aware of messing with porting can result in worse performance than stock, that's why I would only clean and optimize the ports itself, but not touching the windows as long as I don't know what I am doing. That's exactly why I asked here, because I was hoping somebody might have some experience porting these DTs and could give me some numbers to work with.
Regarding the VForce I made different experiences. First of all I didn't buy the original ones, this piece of plastic is something you can buy cheap in all conscience. I got mine for 20€ each and replaced the stiff carbon reeds with glass fibre and put it on my RD350LC. It works really really well. So I thought this should also work on singles. But I noticed on the DT you HAVE to work on the intake, not only because it wouldn't fit, but also because of it's shorter length into the port, leading the gas flow against a hump before entering the barrel.
I've already found the handbook you are talking about, really nice! I will definitely take this to heart :)
About the piston: I found a local dealer in my town who bought lots of TKRJ pistons, when visiting I saw lots of them for the DT175MX on his shelves. Definitely going to get a few of them :)
Edit: May I ask you how you analyze the pipes design for porting? My attempt would be to find out the power band the exhaust likes, but with these old rev counters it's more guess work :D
Last edit: 12 Jan 2026 13:47 by davidivjak.
12 Jan 2026 13:44 #7
You use a tape measure and a calculator along with the exhaust port timing.  Or there are pipe design programs on the web.  Basically you "reverse engineer".
With porting, bigger passages are not always better.
The following user(s) Liked this Post: Snglsmkr, pabdt, Ht1kid
12 Jan 2026 13:54 #8
  • davidivjak
Some news from me and my DT175MX!
I finally made it to put on the 28mm flat slide carb and find a tuning which feels good.
Also I took of the cylinder and cleaned the ports, which means opening up the intake to fit a VForce 3 with fibre glass reeds and fully opening up the boost port, also did some minor improvements on the transfer ports and cleaned the exhaust. I didn't touch the port timing yet, as I still don't know what I should do there.
In addition to that, I replaced the original intake manifold with one from a RT180, because it already has a connection for a hose so I could experiment a little with a self-made boost bottle. For volume, hose length and inner diameter I used the boost bottle calculator from Michael Forrest.
Well, feels like the DT is flying now! Runs really really good, also the boost bottle is doing its thing. And I couldn't believe it, but it consumes less fuel now than stock... originally it took 7 liters, now it's around 6,1 to 6,5 liters. Well, still have to fine tune the main jet, but it doesn't really feel too lean. Have to find a place where I can test full throttle without getting in danger and check the plug (I live in very urban area). It's a 250 main jet now, pilot jet is 30 (which feels one step too rich), needle clip on 4th position from top.
I also got the port timing calculator from Forrest and got a spare cylinder, so this would be my next project for the DT.
Ahh how I love this little bike!
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid, pahiker
25 Mar 2026 11:53 #9
Congratulations!
25 Mar 2026 12:56 #10
