Speedo drive gear swap - What tool ?
  • tee_cee
  • tee_cee's Avatar Topic Author
Speedo drive gear swap - What tool ? was created by tee_cee
Hi All,
I found a good 21 inch wheel to replace my 19 inch front wheel.  I need to swap the speedo drive gear from a donor brake assembly to my brake plate.
I can't figure out how to get the 'bush' out that retains the worm gear - it looks like it has some sort of internal slots.
Grind down a screwdriver to fit ?
Have any of you found a good way to do this?
Thanks!
02 Aug 2026 16:52 #1
Replied by RT325 on topic Speedo drive gear swap - What tool ?
www.cmsnl.com/products/meter-gear-bush-t...2/#compatible-models
Just grind the centre out of a wide screwdriver.
The following user(s) Liked this Post: 1971DT250, swm, tee_cee
Last edit: 02 Aug 2026 17:42 by RT325.
02 Aug 2026 17:41 #2
