73 CT3 175 itermitent spark
  • tsmitty1958
  • tsmitty1958's Avatar Topic Author
Replied by tsmitty1958 on topic 73 CT3 175 itermitent spark
Update. After replacing points and condensers and even buying a stator on line, I read that resitor spark plugs are no good for these engines. I bought NGK B8ES from 2 difffernet vendors claiming to be the right plugs, and each came with the letter "R" on them. So, I found another vendor and made sure they were B8ES with no "R".
2 bikes with weak/intermittent spark. New plugs, both started on first kick!!!
The following user(s) Liked this Post: Ht1kid, pahiker
25 Apr 2026 08:43 #21
Replied by adguy2112 on topic 73 CT3 175 itermitent spark
I believe the resister plug is fine as long as you use a non resistor cap but others can confirm. Such a bummer NGK stopped offering the B8ES and other heat range models of that plug.
29 Apr 2026 03:10 #22
Replied by pahiker on topic 73 CT3 175 itermitent spark
I've used a resistor plug with a resistor cap and it ran fine. I got a non resistor cap and used a resistor plug and it had a brilliant blue spark. Also ran fine. Non resistor cap makes it easier to get compatible plugs.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
29 Apr 2026 05:59 #23
