73 CT3 175 itermitent spark
Replied by RT325 on topic 73 CT3 175 itermitent spark
Have you tried starting it. I had one at work in the "70's that had an almost invisible strand of something conductive bridging the terminal of the points to the nearest thing it could find to earth it out. Magnets had found something & spat it off there.
20 Mar 2026 14:56
#11
- tsmitty1958
Replied by tsmitty1958 on topic 73 CT3 175 itermitent spark
Yep tried starting. Not even a sputter.
20 Mar 2026 15:27
#12
- tsmitty1958
I've had the mag off numerous times and never thought about the magnets picking something up. I'll give that a check.
21 Mar 2026 06:59
#13
- pabdt
Replied by pabdt on topic 73 CT3 175 itermitent spark
So, had problems with my 125 running INTERMITTENT today...AND recently. Pulled tank off to look the coil over and found a LOOSE connection!! Bike runs great now.
This is just a FYI to check the unexpected. I didn't think I would find this problem.
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1973 Yamaha DT3 250
1974 Yamaha DT125A
- tsmitty1958
Good news for you.
I pulled the stator off one of mine that are running and great spark. Check the primary coil and only reading 2.8. Book says 4.9 +/-.
Looking for some one to rebuild as I'm not sure I could do it.
Congrats on the easy fix.
Ts
Ts
24 Mar 2026 15:12
#15
- tsmitty1958
I bought new points and condensers and installed both. Still, very intermittent weak spark. So, I checked the primary coil and it checks out good. Got disgusted and was going to spend $300 on a stator rebuid. BUT first, I decided to try another set of points and another condenser. Another $120 ( for 2 of each). Put the stator on the bike and guess what??? Spark!!!
Now I just have to get the exhaust unplugged and I can try starting it.
Fingers crossed.
Ts
Fingers crossed.
Ts
26 Mar 2026 07:55
#16
Replied by Gr8uncleal on topic 73 CT3 175 itermitent spark
Who were the suppliers and/or makes of the parts that didn't work? Others here will then know to avoid them!
The following user(s) Liked this Post: pabdt, Ht1kid
26 Mar 2026 08:46
#17
Replied by MarkT on topic 73 CT3 175 itermitent spark
Even brand new point contacts often need to be cleaned on magneto systems. (Not sanded or filed, just cleaned properly)
26 Mar 2026 08:49
#18
- tsmitty1958
I have another stator with same problem so I'll try these new ones on that and see if it works a second time and report back. I did file and then used contact cleaer as well on all before installation.
GR Motorcycle in Canada worked condenser.
bikebuzzard2 in Michigan worked for points.
Retro-motorcycles did NOT work.
All on Ebay.
All on Ebay.
26 Mar 2026 09:38
#19
- tsmitty1958
Another stator fixed! "New" condenser/ points. Spark!
The following user(s) Liked this Post: pabdt, Schu, Ht1kid
27 Mar 2026 13:52
#20
