1972 won’t start-do I need a battery ?
- Srk97001@gmail.com
1972 won’t start-do I need a battery ? was created by Srk97001@gmail.com
I finished my 1972 CT rebuild. Got it sight unseen and not running, replaced pretty much everything including points. I have gas and spark, new top end with good compression but it will not fire. Thought it might be poor timing job by me. But also realized that maybe I should Have a battery, clearly that is missing. Do I need a battery to kick start a CT2? Any other ideas?
- DaveHunter
Replied by DaveHunter on topic 1972 won’t start-do I need a battery ?
Do not need battery, spark proves that.
I have a ‘73 CT & don’t remember timing spec but like all two strokes it’s slightly before top dead center. That’s pretty important as too early and it kicks back and backfires , if spark occurs at top dead or after very difficult to start
Beyond than that I’d look at spark plug
Dry ? No gas is getting there = bad crank seal/ carb problem etc
Wet ? Flooded with gas & needs drying out. Sometimes if it’s been sitting for a long time there’s old gas and oil in base so that’s getting flung up against the spark plug and it just won’t ignite .
The air / gasoline mixture will only ignite in a pretty narrow range too much of one or the other and no go.
21 May 2023 19:36
Replied by Srk97001@gmail.com on topic 1972 won’t start-do I need a battery ?
Thanks, I replaced all seals tried the OEM carb with a rebuild and a aftermarket one, same poor results. Towed behind a truck to pop start, every 20’ or so it would sputter. Anyone have a link to a good video to time this thing?
21 May 2023 19:48
Replied by MarkT on topic 1972 won’t start-do I need a battery ?
Be careful without a battery. Really easy to blow light bulbs if it does start.
21 May 2023 19:55
- darinm
Replied by darinm on topic 1972 won’t start-do I need a battery ?
Maybe a little of heresy; but some starter fluid will tell you if it's a timing issue, if it wont start after a spray of starter fluid then the timing is off or it's not sparking under compression. If it starts and runs a few seconds on starter fluid, then dies, the fueling is where I'd look.
As always agreeing with MarkT. You'll want a battery sooner or later, save some bulbs and put one in first.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
21 May 2023 21:10
Thanks, yup it will not start with starting fluid either....i replaced the points as a maint. item new ones look cheap compared to the OEM which were in good shape so i put the old ones back in.
What color wire comes from the points so i can figure out when thy just start to open?
22 May 2023 12:28
Replied by Ht1kid on topic 1972 won’t start-do I need a battery ?
It’s the black wire going to your coil you can download the service manual from the library
22 May 2023 13:41
Good looking bike clean your original points really good and set the gap at 15 thousands and you should be close enough to see if you have spark also do you have a new spark plug
Also if you still don’t get spark unplug your ignition switch more pictures will help
22 May 2023 15:53
I have a very good spark visually checked out of the bike and verified with a spark indicator while installed. Wondering if I reconnected the leads correctly. Colors except for the green and red striped one seemed pretty obvious. Anyone see anything out of place? Still won’t start even with starting fluid. Gapped points to 0.013 best I could, dial indicator will come tomorrow to find TDC and back off.
