72 Yamaha LT2 - Hard to put in Neutral
  • Le7316
  • Le7316's Avatar Topic Author
Replied by Le7316 on topic 72 Yamaha LT2 - Hard to put in Neutral
So in order for me to see that ..I have to remove the cover completely? ☝️
04 Aug 2022 20:28 #11
Replied by MarkT on topic 72 Yamaha LT2 - Hard to put in Neutral
Not sure what "that" you are asking about.  Neutral detent cap with spring and ball underneath is right on top of engine.  Easy to check if it's there. Without it, neutral will be hard to find.
Actuator worm gear is under cover.
04 Aug 2022 21:13 #12
  • Le7316
“ Neutral detent cap with spring and ball underneath is right on top of engine. “ is this where clutch cable attach to the engine ? I have posted my engine pic above .
04 Aug 2022 21:50 #13
Hope this along with the several descriptions I wrote already and parts diagram helps you understand where detent cap is?
04 Aug 2022 22:17 #14
  • Le7316
I see it now and I also noticed there is a wire attached to that hex bolt . Now, can I just remove the hex and verify it ? How easy to see the ball and the spring after the hex is removed ?
04 Aug 2022 22:40 #15
No, that is the neutral switch.
As I previously described, the detent plug threads in at an angle just to the rear of the neutral switch.
It's hard to see in your picture which is why I used a bunch of arrows to surround it.
04 Aug 2022 22:58 #16
  • Le7316
Hahaha I must be blind but yes I see it .
04 Aug 2022 23:06 #17
Yes!
Spring pulls right out...  probably need a magnet to pull out ball.
It's not too common to be missing on that model but since you don't know history, it could be.  Someone else here had the same problem with neutral and theirs was missing...  actually I think spring and ball might have been in a box of parts they got with bike.
Anyway, it's easy to check.
The following user(s) Liked this Post: Le7316
04 Aug 2022 23:45 #18
  • Le7316
I will check hopefully tomorrow and update it . Thanks for the helps !!
04 Aug 2022 23:48 #19
Replied by RT325 on topic 72 Yamaha LT2 - Hard to put in Neutral
Just had a thought, to save yourself the trouble. With motor not running you can feel neutral quite positively by hand & just put it down into first--might need to move bike an inch to engage--then hand pull it up to neutral which is a half movement. It'll give a positive feel click & can then wheel it along being neutral. Don't pull it up hard or it'll go through to second. I'm outa here & off to bed--got covid yesterday despite doing everything right. Not recommending it!!. No fun at all.
05 Aug 2022 02:07 #20
