72 Yamaha LT2 - Hard to put in Neutral
  • Le7316
  • Le7316's Avatar Topic Author
Do all Enduros are like this ? I had shift up and down a few times just to get in a Neutral …wondering what could it be ? Or this is normal ? Not saying I couldn’t get it in NEUTRAL AT ALL but having a hard time …
04 Aug 2022 13:02 #1
Replied by Tom P on topic 72 Yamaha LT2 - Hard to put in Neutral
Have you ridden for a while, or are you new to riding Yamahas? I know that initially, and this is many many moons ago, it took a little bit to get used to hitting neutral, but after a while it comes to you. Just shift all the way down to first, then a very gentle lift up. Also seems to work easier if you go into neutral as you're coasting to a stop.
04 Aug 2022 13:21 #2
Replied by MarkT on topic 72 Yamaha LT2 - Hard to put in Neutral
High idle speed or dragging clutch can make it hard too.
Also make sure you have the neutral detent spring and ball under the cap on top of the engine just above the front sprocket area.  #25 though #28 in diagram here:  www.partzilla.com/catalog/yamaha/motorcycle/1972/lt2/shifter-a
04 Aug 2022 13:54 #3
Replied by Swoop56 on topic 72 Yamaha LT2 - Hard to put in Neutral
A too viscous gearbox oil will cause the clutch to drag , and makes finding neutral tricky .
It might be worth changing out .
04 Aug 2022 14:06 #4
  • Le7316
Replied by Le7316 on topic 72 Yamaha LT2 - Hard to put in Neutral
How do I check if they are installed ? I only own this bike for more than week. Here is the pic of the engine .
04 Aug 2022 14:32 #5
  • Le7316
The previous owner told me he’s using the Lucas Motorcycle 10w-40 oil on this engine . Good enough ?
04 Aug 2022 14:35 #6
Replied by RT325 on topic 72 Yamaha LT2 - Hard to put in Neutral
  Unlikely but worth mentioning. 28 is the neutral locating ball & spring. I'm still leaning towards clutch drag though. & if it is that & you have it apart then leave out the rubber spreader rings as cause more trouble than they're worth. Pic coming shortly No7 in the clutch pic & if in there, there should be 4 of them.
Last edit: 04 Aug 2022 15:53 by RT325.
04 Aug 2022 15:50 #7
Stupid me haha. MarkT is way ahead of me. Read before writing i should!!.
04 Aug 2022 15:55 #8
Also clutch actuator No3 likes being lubed if you can get some oil into it. Pic is a bit confusing as doesn't come apart to lube so just move it & get oil into it or grease but won't flow like oil. I see they call it 'push screw' for want of a better word.
04 Aug 2022 16:13 #9
Right behind the neutral switch is a hex head plug at at angle.  Kind of hidden by clutch cable in your picture.  Spring and ball should be under that.
That oil should be fine.
04 Aug 2022 16:48 #10
