gears not in alignment
- maxx2395
gears not in alignment was created by maxx2395
HI All
I am frustrated, the drive gear on the crankshaft
does not look like it matches the driven gear on the
clutch hub The drive gear is installed correct because
the position of the nut. the driven gear is about
one eight of an inch out.
If anybody knows if this correct or if I need to take it apart
again. I am using the CMSNL website to assemble it.
Thanks for your time
Maxx . . . . .
Maxx . . . . .
30 Jun 2022 12:06
- Tinkicker
Replied by Tinkicker on topic gears not in alignment
Are we talking about a kawasaki Z900 or a Yamaha V Max?
30 Jun 2022 12:43
- maxx2395
Replied by maxx2395 on topic gears not in alignment
HI All
I really need some sleep, sorry but I am working
on a 1972 yamaha at2 soon to be running as a
nice patina bike.
Thank you for your reply so quick.
Maxx . . . . . .
nice patina bike.
Maxx . . . . . .
30 Jun 2022 16:20
Replied by RT325 on topic gears not in alignment
We love pics of course, but i don't think they ever line up perfectly central to each other. So long as the clutch has any washers that are meant to be behind it--in place there's nothing else i can think of just yet. Are there signs of part of the crank gear never having been turned against during its life.
30 Jun 2022 16:38
Replied by MarkT on topic gears not in alignment
Didn't you just post this same question yesterday in a different post? Answers were given there. And a request for photo. It's going to be really hard for us and you to follow along if you keep doing that.
yamaha-enduros.com/index.php/forums/1972...17795-clutch-o-rings
30 Jun 2022 19:51
- maxx2395
HI
I didnt think the subject went through, so
I sent it again, but thanks for the quick reply.
It is appreciated.
Maxx . . . . .
PS I tried to delete it but I cant figure out how.
It is appreciated.
Maxx . . . . .
01 Jul 2022 09:37
- Tom P
Replied by Tom P on topic gears not in alignment
Still no photo? If you want to get some help on this issue, you've really got to post detailed photos, and details of your bike. I can't remember what mine looked like, but if you're only talking about 1/8" off, that might be completely normal. When helical gears engage, they tend to move a bit laterally anyway, so may actually be in line when they are under load But again, a few good pictures would be worth a million words.
You're good. Some people have come on here and posted similar/same question and updates in a new topic every time. They miss half the replies. And nobody can follow along. It's very confusing.
Just make sure you check the last few of your disc thread I linked to and then continue here is probably best? I think I can close that other one if you want me to so people can't add posts there.
01 Jul 2022 09:51
- maxx2395
HI
So I couldnt see any wear marks on the gears, does not have many miles on it.
So I took the clutch back apart, the sleeve the bearing and the shim
are correctly installed. so I put it all back together, after falling down on the
cement in my garage OWUUUUUCH. and It is correct. going to take me a while to stop hurting.
I thank everyone for the quick response. Hope all of you have a great ride.
Maxx. . . . . .
Maxx. . . . . .
The following user(s) Liked this Post: MarkT, AirborneSilva
01 Jul 2022 11:01
- carter6787
Replied by carter6787 on topic gears not in alignment
I just rebuilt my RT3 engine and found out if the clutch thrust bearing and thrust washers are not installed correctly it will cause the driven grear to be misaligned to the primary crankshaft gear and it WILL CAUSE PROBLEMS if you do not fix it. There are diagrams in the Yamaha manual showing how to install them correctly.
