Tail light goes dim when I apply brakes - DT2
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic Tail light goes dim when I apply brakes - DT2
Everything seems to be working correctly now, well except I need to get a new flasher since the old one isn't working, it clicks when you put the signal on but they just stay lit.  I put insurance on it today and will be visiting DMV tomorrow to register and start enjoying
05 Jun 2022 11:31 #21
Is it possible the flasher bulbs don't match the relay. Wattage needs to be in the ball park for it to trip.
05 Jun 2022 16:43 #22
  • AirborneSilva
  • Platinum Member
  • Platinum Member
That's a good point, I'm using the bulbs that came with the aftermarket signals.  When you apply the turn signal you can hear the flasher click once, if that means anything...
05 Jun 2022 16:56 #23
RT325 is likely correct from what you've said...  you probably have incorrect 12v bulbs in the lights which won't load the OEM flasher unit enough to work.
Couldn't hurt to check and getting a more modern 6v two wire flasher unit is not a bad idea either.
05 Jun 2022 17:15 #24
I use 1129 bulbs in my turn signals you can get them at autozone etc
Last edit: 05 Jun 2022 20:41 by Ht1kid.
05 Jun 2022 20:39 #25
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thank you Mark and thank you Ht1Kid for the bulb number.
06 Jun 2022 01:43 #26
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Good call on the bulb voltage, the rear bulbs are indeed 12v but the fronts are 6v.  I was wondering why the rear was so much more dim than the fronts.  I'm learning
06 Jun 2022 02:53 #27
try putting two 6v bulbs on one side of bike and see if that side flashes...  that will tell you if flasher will work.
The following user(s) Liked this Post: Snglsmkr, Ht1kid, Sneezles61
06 Jun 2022 07:11 #28
  • AirborneSilva
  • Platinum Member
  • Platinum Member
You guys are dead on and is why I like this forum so much.  I installed 6v bulbs and what do ya know, I have turn signals now that actually blink
Went to DMV, registered the bike and took it for a 20 mile ride.  I found out I do need a new oil tank as it's leaking, when I cleaned it up I thought I saw some cracks in it so I'll be on the hunt for a replacement...
Thanks to all for the help!
The following user(s) Liked this Post: MarkT, RT325, Gr8uncleal, Ht1kid
06 Jun 2022 08:29 #29
So--as they used to say--many hands make light work!!
The following user(s) Liked this Post: MarkT, Snglsmkr, AirborneSilva
06 Jun 2022 16:18 #30
