Tail light goes dim when I apply brakes - DT2
- AirborneSilva
Tail light goes dim when I apply brakes - DT2 was created by AirborneSilva
Alright guys I'm getting very close to being able to register my DT2 for street use, Deet rebuilt my key switch/harness (and did one hell of a great job), so now I have everything working but when I apply either front or rear brake the tail light goes dim instead of getting brighter, the battery is 100% charged. Any thoughts? Thank you, Tony
03 Jun 2022 11:46
- Swoop56
Replied by Swoop56 on topic Tail light goes dim when I apply brakes - DT2
Check your earth wires to rear tail light , frame , and connection to
main wiring loom , from tail light loom .
Check wattage of tail light bulb .
- AirborneSilva
Replied by AirborneSilva on topic Tail light goes dim when I apply brakes - DT2
Thank you, I'll do that. I did just get a new bulb from Partzilla but that's not saying it's correct, they have sent me wrong parts before...
03 Jun 2022 15:22
Replied by Ht1kid on topic Tail light goes dim when I apply brakes - DT2
Bulb should be 1154 maybe you accidentally wired the run light and brake light backwards you can swap the wires on the rear fender and see if that works correctly. Ask me how I know!!
03 Jun 2022 15:37
- AirborneSilva
Thanks I'll check bulb, as for wiring I checked to see they are connected correctly color wise and they are...
03 Jun 2022 15:39
Take your lens off and see if both filaments are on in the run position and if one goes out when you apply your brakes maybe your wiring in the front got crossed. Seen it happen before
03 Jun 2022 15:49
- Lizeec
Replied by Lizeec on topic Tail light goes dim when I apply brakes - DT2
Verify bulb is correct part number and verify it is inserted correctly, they are suppose to only go in one way but they can be forced to be inserted incorrectly, although as mentioned above your symptoms point to a bad ground in the taillight circuit.
03 Jun 2022 17:31
- AirborneSilva
Thanks guys, I have my marching orders.
04 Jun 2022 02:01
Replied by RT325 on topic Tail light goes dim when I apply brakes - DT2
So does the brake light work normally without motor running--as you say battery is right up. If it's only doing that with motor running--which i guess is what ya saying--then whats up with the bulb. Is it fitted back to front, not easy to do with offset pins. I've had the odd bulb break a filament then lean over & contact the other filament causing total confusion. Seen the little fitting that the wires attach to where bulb contacts & someone had managed to get that back in half a turn out--also not easy to do. Probably just an earth problem in the end. Don't ya love electrics.
04 Jun 2022 02:37
- AirborneSilva
Without the motor running I get nothing when applying brakes, also don't have a tail light and I thought the tail light should be on even if motor is not running...
04 Jun 2022 02:43
