Mikuni Setter Jet
  • EM ONE
  • EM ONE's Avatar Topic Author
Mikuni Setter Jet was created by EM ONE
Im trying to source a setter jet for a mikuni VM 32 Sh carburetor here in the UK,,The carb is marked 308 E2,, im assuming its the original for my 73 rt 360,i will also need the washer,if i cannot get one from these shores i may have to try the USA,but id rather not pay more for shipping than the item. Can any of you out there point me in the right direction, cheers in advance.
15 Jan 2022 17:06 #1
Replied by KennyV on topic Mikuni Setter Jet
There are options to eliminate the jet setter,
yamaha-enduros.com/index.php/forums/gene...location-of-main-jet
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
15 Jan 2022 17:28 #2
Replied by RT325 on topic Mikuni Setter Jet
Here is a jet setter i found googling away. Price is high--but. Did you break the thread off yours as i've come close to doing that but had a spare. Couldn't find the washer [checked his other listings too]. Any washer would do but original brass washer is quite thick & probably helps the Oring get fully compressed down past the taper start of the bowl cavity. If i was stuck i'd screw a main jet direct into the needle 'jet with a washer'. Thread is slightly different but can be done.
Needle Jet Emulsion Tube Setter MIKUNI Carb 308 E2 1972 Yamaha RT2 RT1 RT3 360 | eBay
15 Jan 2022 19:42 #3
Replied by Gr8uncleal on topic Mikuni Setter Jet
"Im trying to source a setter jet for a mikuni VM 32 Sh carburetor here in the UK"
Motocarb should have what you want.
Last edit: 16 Jan 2022 00:58 by Gr8uncleal.
16 Jan 2022 00:58 #4
  • EM ONE
Replied by EM ONE on topic Mikuni Setter Jet
Great responces ,ive emailed Motocarb hopefully they can help,i dont want to go down the alternative route,and the one in the US on ebay may be my last expensive resort,and yes the carb body came without the Setter in place,it was separate with the threads missing.
16 Jan 2022 13:23 #5
  • EM ONE
Sorted it,Motocarb had one in stock,brilliant I searched everywhere ,cheers once again
19 Jan 2022 07:32 #6
"Sorted it,Motocarb had one in stock,brilliant I searched everywhere ,cheers once again"
Hopefully they're not sending you the one that they put to one side for me!
19 Jan 2022 07:47 #7
Replied by msavitt on topic Mikuni Setter Jet
Niche Cycle has jet setters at a reasonable price.  Not sure if they have the exact one you need
19 Jan 2022 08:18 #8
Keep in mind there are two different types / styles of the jet setter. There's one that has same thread as main jet for the 159 type needle jet and there's one with different thread for the 188 type needle jet. Just a thought.
71 Z50 Minitrail
21 CRF300l Rally
Last edit: 19 Jan 2022 11:06 by KennyV.
19 Jan 2022 10:19 #9
Replied by Horswill on topic Mikuni Setter Jet
So would the setter jet from a 1974 DT250/DT360  # 276-14145-00 be the same as a 1973 RT360 # 214-14145-00
Would it work?
29 Jan 2022 23:19 #10
