RT-2 ignition switch
- Fudsy1
RT-2 ignition switch was created by Fudsy1
Trying to get working lights on my RT-2 360. Have power from the battery to the switch, and none after. Took switch apart and there is power to the first disc and not switching when key is turned. Jumped power to the tail light and it works so, wiring is intact. Power off the lighting coils cause the horn works
with engine running. Someone was in to the switch before, cause there are two new solder spots on the switch. Maybe the bad solders or switch put back together wrong? I"m running out of ideas!!!
07 Jan 2022 10:53
- RT3Sam
Replied by RT3Sam on topic RT-2 ignition switch
Fudsy, I don't have any advice. But I am interested in what you find out. I just rebuilt(with old parts) my ignition switch and I don't have light either. Hope someone can help us both.
The following user(s) Liked this Post: Fudsy1
07 Jan 2022 11:24
Replied by Ht1kid on topic RT-2 ignition switch
Welcome aboard!!! Contact DEET he is a member here. Does top notch repair on ignition switches
The following user(s) Liked this Post: Hardworker, Fudsy1
07 Jan 2022 11:29
Replied by Gr8uncleal on topic RT-2 ignition switch
Lights only work with key turned into the second position ( ie off, position #1, position #2).
Do you have a means of circuit testing? If you do, go to the wiring diagram in the Service Manual (in the Tech Library on this forum) and there you will see a diagram of which wires should make contact with each other in each switch position. Disconnect the switch wires under the tank, carry out the test and report back!
07 Jan 2022 11:37
Also, here's a link to a post that I made showing where each wire sits on the switch base.
DT2 DT3 RT2 RT3 main ignition switch wire positions - Vintage Enduro Discussions (yamaha-enduros.com)
07 Jan 2022 11:44
A lot of (most?) original headlights are blown by now, due to the "balanced" electrical system going out of balance! Basically a 6v voltage regulator needs fitting and Yamaha produced a Service Bulletin on this subject - this explained why and how and it can be found in the Tech Library.
07 Jan 2022 12:07
- Fudsy1
Replied by Fudsy1 on topic RT-2 ignition switch
What I am seeing is that none of the wiring diagrams i've come across match up with the switch. I basically have a keyed kill switch. Ordered a new switch but it's backlogged from Yamaha, no ETA etc. etc etc!
Only thing I can possibly guess is the the wiring harness or switch has been changed out and has different wiring.
Waiting till i get the new switch before resorting to re soldering the switch contacts.
So, we wait on parts! Can't hardly bitch about waiting on parts for a 50 year old machine!
13 Jan 2022 12:22
