DT2 headlight bucket alternatives
- AirborneSilva
DT2 headlight bucket alternatives was created by AirborneSilva
Has anyone replaced there stock DT2 headlight bucket for a more modern bucket that can/will accept a newer sealed beam light?
06 Jan 2022 03:52
Replied by MarkT on topic DT2 headlight bucket alternatives
When searching, make sure you are on "search forum". A simple phrase like "replacement headlight" yields many results including NAPA 4020 sealed beam. 4020 or a common 5 3/4 H4 reflector fits in the stock rim by simply using spring clips from a later model.
Clips can be bought from Yamaha or MikesXS. www.mikesxs.net/yamaha-xs650-headlamp-w-clips-pk-5.html
You can buy a kit from Pobit on ebay but he is away until the 24th.
06 Jan 2022 07:11
- AirborneSilva
Replied by AirborneSilva on topic DT2 headlight bucket alternatives
Thank you Mark! I may try installing a regulator (not sure if it has one, haven't looked), and give it one try with stock setup, I did find one for $81, I'd rather not waste the money but am trying to keep things as simple as I can since I'm not that great with electrical.
If all else fails I'll check out Pobit and see what he's got.
06 Jan 2022 14:22
- adguy2112
Replied by adguy2112 on topic DT2 headlight bucket alternatives
I’ve been playing with a different way to hold the 4020 bulbs in where Yamaha clips won’t work. It’s not perfected yet but here is a quick attempt. Want to use thicker rigid plastic and better springs but this one is holding tight Against the rim.
06 Jan 2022 21:36
- AirborneSilva
Looks like you're headed in the right direction adguy2112, thanks for the pictures.
07 Jan 2022 02:34
- adguy2112
Alright, I think I have this sorted out. Cut out the bottom of a cheap plastic cereal bowl, picked up some short springs and drilled a small pilot hole below the old swivel anchors. Worked perfectly. Light is held tightly against the rim and even has some vibration absorption. Perfect for the 4020 replacement bulbs. Pretty stoked.
07 Jan 2022 21:37
- AirborneSilva
Looks good ADGUY2112, my only concern is left and right adjustment. Maybe it's not needed, don't know, but I like the simplicity of your fix...
08 Jan 2022 02:28
- AirborneSilva
Just a thought but have you thought about adding something like
this
to keep the springs from ripping through the plastic...
08 Jan 2022 02:38
Replied by Ht1kid on topic DT2 headlight bucket alternatives
Adguy great idea
08 Jan 2022 06:11
- Sneezles61
Replied by Sneezles61 on topic DT2 headlight bucket alternatives
Out of the box thinking! Will it get too hot and warp the bowl? You'll keep us in the loop 2112, eh? (a fantastic album from Rush)
Airborne, can you just turn the handle bars.. left or right? Clowning there...
Sneezles61
Sneezles61
08 Jan 2022 15:22
