RT3's Only
- RT3Mike
RT3's Only was created by RT3Mike
Does anyone know if the '73 RT3 came with:
1. Blinkers or were they an option.
2. Only one type of rear shock - the adjustable one's.
My bike does not have blinkers. I purchased my bike from the original owner (so he says) and he said blinkers were an option in '73 because they were not yet mandatory on motorcycles until '74.
He also said the rear shocks are the original shocks, but mine are not adjustable and don't look like those I see in most original photographs.
This being said, does anybody have an extra set of front and rear blinkers and/or rear shocks laying around. HAR!
Thanks Mike
Thanks Mike
12 Jul 2021 15:18
Replied by RT325 on topic RT3's Only
Defo had blinkers down here in nz. & also had the adjustable shocks. Not talking the reservoir shocks from "74 just the chrome usual spring adjustables. Had blinkers "flashers" before that too.
12 Jul 2021 15:26
- RT3Mike
Replied by RT3Mike on topic RT3's Only
That's what I was afraid of.... I've been douped. Back to my second set of questions... does anybody happen to have a set of blinkers/flashers laying around as well as correct rear shocks?
12 Jul 2021 15:35
- DEET
- Moderator
Replied by DEET on topic RT3's Only
Turn signals came stock on US bikes in 1971.
Shocks were adjustable.
- 1971DT250
Replied by 1971DT250 on topic RT3's Only
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=191144730869&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- RT3Mike
1971DT250 - Great tip. Did you buy the shocks from the same seller you just sent me?
I am watching ebay for flashers, Nothing very good right now. I have seen the repops, but they are orange lenses front and rear. I am yet to see the repops with the rubber bushings. and some of the mounting brackets dont look correct. Please let me know if you know of any.
12 Jul 2021 17:03
- 1971DT250
Yes, good price and nice quality. They are a little longer than stock and make the bike sit up a little higher,
Also the spring diameter is a little wider and comes close to the exhaust but doesn't cause a problem.
12 Jul 2021 17:28
- RT3Mike
Awesome! I need my bike to sit a little higher so that is perfect. I just ordered a set. Great tip! Thanks so much... Still on the hunt for blinkers/flashers.
12 Jul 2021 17:32
Replied by MarkT on topic RT3's Only
Some states could have different laws but turn signal weren't Federally mandated in the USA on a motorcycle manufactured before January 1st 1973.
Yes, your bike came with them but "technically" not required if manufacture date is in 1972... and many are... look at the sticker on the steering head.
It's kind of a grey area in some places if the motorcycle came with them... check your state law.
12 Jul 2021 17:56
- RT3Mike
I did double check -Jan 1,1973 is correct here in CA. I went and looked at the sticker head, but it is partially rubbed off and right were the date would be, it is completely erased. Is there a way to check by the VIN? Interestingly enough my vin begins with DT1. Maybe that is correct, IDK.
12 Jul 2021 18:02
