LT3 Parts Interchange
- JMKady
LT3 Parts Interchange was created by JMKady
Picked up this little LT3 yesterday kinda spur of the moment because it was dirt cheap. Since getting it home and the initial triage it seems they aren't particularly common bikes and this one needs a lot of love to be a runner it sat outside for quite a while. Are there any other 100cc models that share internal parts with these bikes if it ends up being more than a bearing/seal job?
- 1971DT250
Replied by 1971DT250 on topic LT3 Parts Interchange
'72 LT2 is the same except for the paint. Some of the '71 HT parts are interchangeable.
This one is original, unrestored. Gets a lot of attention.
The following user(s) Liked this Post: SKYDANCER46
08 Sep 2019 10:03
- loner
Replied by loner on topic LT3 Parts Interchange
I have one the same color, am trying to find a paint match. Any ideas?
02 Sep 2021 20:05
- Enduro nut
Replied by Enduro nut on topic LT3 Parts Interchange
Someone a while back made a post about paint matches and it only ever grows. Im pretty sure i remember seeing the grape purple in here somewhere, i too have one i need to do next year.
yamaha-enduros.com/index.php/forums/gene...aint-matches?start=0
02 Sep 2021 20:12
- swm
Replied by swm on topic LT3 Parts Interchange
Marbles Motors on ebay has this option.
02 Sep 2021 21:09
- adguy2112
Replied by adguy2112 on topic LT3 Parts Interchange
speaking of the LTs does anyone know if the single toggle LH/Horn/turn signal switch could interchange with the two switch handle from an LS model? I assume the second toggle is an engine kill switch which I don't think the LTs used. I figure I could just not use that second switch or maybe remove the internals so it's close to NOS. I have the original handle in good shape except the LH toggle is broken off. I don't know if those toggles can be purchased anywhere as a separate piece. I'm already looking at having DEET restore a '69 switch but wanted to try to fix this one myself.
03 Sep 2021 11:32
- Sneezles61
Replied by Sneezles61 on topic LT3 Parts Interchange
If you do the research... I have the toggle from the LH blinker from an RT2... If it'll work, we can get to you.. I like to see it has a home rather than a box out in the shed...
Sneezles61
Sneezles61
03 Sep 2021 11:43
Replied by Gr8uncleal on topic LT3 Parts Interchange
Many models used the YHA205 switchgear (see the id stamp on the underside) in various formats. I have seen them with and without every individual switch, with what is not used fitted with a blanking part (apart from the horn, which sometimes doesn't have the hole for the button drilled).
The YHA205 internals are interchangeable with SOME of the YHA206 internals. However, care needs to be taken, as later YHA206 switchgear had thicker switch stems and therefore wider holes in the switch body.
The upper, black part of the switch was/is available as a separate part, but not the inner part that sits in the body, and which is the part that always gets broken! There is a chap here in the UK that 3D prints replacements (I have bought two from him) and I'm sure that someone in the US must be able to do this.
Sitting on the bike, the left toggle is usually high/low beam and the right one is lights on/off.
03 Sep 2021 11:45
- adguy2112
Sneezles that is a generous offer and one I would love to take you up on. If the stamp is the same sounds as though it will fit. I'll PM you. This little LT2 had all if it's lights and controls stripped before I got it. I've slowly been bringing it back to its original configuration. Still more to do.
03 Sep 2021 12:18
- adguy2112
Great info. Thank you G.
03 Sep 2021 12:21
