HT1B Condenser
  • shyted
  • shyted's Avatar Topic Author
Replied by shyted on topic HT1B Condenser
The condenser is 12mm OD x 26.5 L.
The other condenser is 17mm OD
The three wires are actually source coil ,Ignition coil and contacts. I pulled the sheathing back and found more than what i was looking for. What looked like the source coil wire was actually shrink wrap. That's my solder on melted in with the original .
I found that Bowden cable type wire when i ran a new ignition coil wire in. That's supposed to be new old stock.
Something tells me that's not genuine Yamaha NOS wire.
Last edit: 18 Aug 2021 16:26 by shyted.
18 Aug 2021 10:10 #11
Replied by Ht1kid on topic HT1B Condenser
If I can remember correct I used one for a Honda ct70 for my ht1 but my stator only had 2 coils. I found one that might work for you
20 Aug 2021 16:25 #12
Replied by MarkT on topic HT1B Condenser
I've been scouring docs to see if I can find an HT1b with 3 stator coils...  It seems the 3 coils started with the 72 LT2?
It's possible you have a JDM model that's a little different than the US models or someone has swapped parts over the years too...
Whatever it is, that may be why the "normal" condenser doesn't fit.
20 Aug 2021 17:03 #13
  • shyted
Great stuff thanks. I managed to get one from one of the other members and fitted it today.
It's worked .
Now the spark quality is much better and blue instead of orange.
I went down this rout as i was fault finding . The motor has started cutting out on idle when it gets warm. When i fitted the condenser the bike fired up first prod and ran much better but i hadn't located the fault and it was starting to get worse. While i was running the bike with the case off i could hear a squeaking sound so started looking and listening . Checked my work to make sure nothing was touching the rotor. All okay. With each item i removed, i kicked the motor over checking for the sound and finally arrived at the problem . I looked at the crank seal and saw it straight away. The seal had popped out and the squeak was pressure blowing past the lip on the crank seal. Not a genuine item. It came with a pack of seals i got with the bike .Now i know i can get that one in the UK from Fowlers Yamaha so there'll be one here tomorrow .
Once again thanks for that.
The following user(s) Liked this Post: RT325, Gr8uncleal, Pete-RT1
20 Aug 2021 17:11 #14
Replied by Gr8uncleal on topic HT1B Condenser
Glad it worked out ok, Dave!
20 Aug 2021 23:07 #15
  • shyted
Hahaha, had to laugh. the seal i got with the bike . It's the same make as genuine . ATE !
21 Aug 2021 07:58 #16
