clutch out of order DT 250 A
- AXLE1
clutch out of order DT 250 A was created by AXLE1
Hi there
My bike was out action for 2 years. it all started fine but when I get it into gear after releasing the clutch it stalls. I have checked the leaver and taken the side cover off there is some movement on the plates. Not sure what else is wrong, as why the clutch not working and what is stuck !!!!
please help..
Regards Alex
please help..
Regards Alex
Replied by RT325 on topic clutch out of order DT 250 A
Plates have kind of bonded themselves to the steels. Just remove them & separate then carefully seeing you're already in there. The pressure plate will lift as your looking at it but as I say the rest are stuck to each other. Perhaps give the steels a light sand if look like the shape of each grippy bit is showing on the steels. Could very very lightly do the same with the fibers then go ride it & enjoy. With DT250A I think that the pressure plate might need fitting in the right way or won't fit on the hub. Might be wrong but if there's 3 arrows there's likely 3 marks on the hub to give you guidance. You'll know straight away as won't go on to compress plates. Cheers from NZ.
- AXLE1
Replied by AXLE1 on topic clutch out of order DT 250 A
Hi
Thanks so much for your swift response, I shall certainly will have ago.
Thanks again from Scotland happy easter.
17 Apr 2025 14:57
Replied by Gr8uncleal on topic clutch out of order DT 250 A
To prevent it happening again, and also a less intrusive cure, is to just pull the clutch lever back to the 'bars and tie it there.
And
from near Salisbury.
And
17 Apr 2025 23:14
Just looking at the parts pic the 250 may not have the type of pressure plate I'm thinking of. If that's the case the pressure plate just fits on any which way. Not sure if those have 5mm thread spring screws. Earlier design motors have 5mm & are a disaster, stretch & break off when tightening. If 6mm you'll be good. Just be careful tightening 5mm & eyeball the thread first. But I think it'll be 6mm.
- AXLE1
well a big thanks to all of you , I shall report back the outcome.
Cheers
Cheers
18 Apr 2025 00:49
Sorry, I should have added to leave it overnight in that position!
The following user(s) Liked this Post: AXLE1
18 Apr 2025 01:46
- AXLE1
Hi All
Just came to say following your instructions stripped down checked for ware all within the tolerance assembled back. Prior to put the crank case back together pulled the clutch into first gear and rolled the bike I could see the plates moving. All back together and test ride fine.
Well a massive thank to all you having a classic bike is a privilege, but learning & getting to know the other enthusiasts is an honour.
18 Apr 2025 08:10
Well done.
Photos of the bike would be great, although you need to use a third party host such as Imgur to post them here.
18 Apr 2025 08:29
Moderators: yamadmin, Makotosun, DEET, Vinnie
