DT360
- jsmith6752
DT360 was created by jsmith6752
going over the schematic for the 74 DT3600. What is FWN stand for? When the key is turn on what does it energize before starting the engine? Still looking for a home for my hot wire. thanks
The following user(s) Liked this Post: 2strokenewb
20 Nov 2024 07:47
- pabdt
Replied by pabdt on topic DT360
What color is wire? Not in front of pc at this moment, but recall power for horn (brown) and brown/white for turn signals.
Key on for your bike = brown wire hot. Should have front/rear stop lamp, horn, turn signals.
Post pics with your posts if poss
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
20 Nov 2024 12:34
- jsmith6752
Replied by jsmith6752 on topic DT360
strange going on my right front turn in the front blinks but stays on between flashes. You can hear the difference from the relay. It does not go completely off between blinks. I don't have a clue
20 Nov 2024 17:14
Replied by RT325 on topic DT360
no clue here either sorry but hope someone elightens us that don't know.
20 Nov 2024 17:22
- pabdt
How does somebody not knowing enlighten you?
can somebody combine all these threads?
anybody think bulb wattages could be an issue?
1969 Yamaha CT1 175
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
20 Nov 2024 18:36
- pabdt
Jsmith, you need to read the docs mentioned and when you get hung up ask about things. These old 2 strokes require a bit more reading to get a good handle on the electrical and other systems on bike.
1969 Yamaha CT1 175
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
20 Nov 2024 18:47
- jsmith6752
thanks guys
20 Nov 2024 20:02
Ok, one more go. If the wattage's were too low they'll come on but not flash--or blink as i say.
But on the other hand if the wattage is too high-way too high-would that make them do what you say?.
Do they flash at a normal rate or flash crazy fast so doesn't have time to extinguish fully in the globe wire thingy between flashes?.
Bulb wattage must match the relay --what's written on it--but can usually go one higher, like-an 8watt relay can run 10 watt bulbs with a slightly faster flash.
They calculate the indicator 3watt bulb in the tacho into the equation as well. Also be sure you aren't running 12 volt bulbs by mistake or a 12volt in the tacho indicator warning light.
- jsmith6752
I did check all my bulbs tonight. They were ok. The right one flashes bright but stays on dim between flashes. The bulb socket has some rust in it. I will try to get my dremel in there with a wire brush to see if that helps...I hooked up my regulator tonight so I will give it a go tomorrow.
20 Nov 2024 20:35
Bad earths can cause feedback through things & cause headaches.
Try individually running an earth wire from each bulb socket to the bare frame, anywhere will do even motor fins or head, providing engine bolts are tight.
Just try each bulb socket separately while switched to 'that side'.
Or if you have 4 spare jumper leads just do them all at once--well each side anyway.
Moderators: yamadmin, Makotosun, DEET, Vinnie
