Re:Re:CT175 Milled head worth it?
- Dogboy
Replied by Dogboy on topic Re:CT175 Milled head worth it?
I Have a webco head that I believe is for a CT 1, 2 or 3. It was advertised as fitting a 175 A, B or C. However someone had cut the fins to clear the exhaust as it crosses over on the DT 175's.
25 Oct 2026 18:00
#21
- pabdt
Replied by pabdt on topic Re:CT175 Milled head worth it?
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
26 Oct 2026 01:12
#22
- Rick C.
Replied by Rick C. on topic Re:CT175 Milled head worth it?
Don definitely had the CT3 bike to beat at all the ENDURFEST's starting from the 2010
season till well pretty much today.
He rode it everywhere!
It was a perfect workhorse.
I heard it has the infamous sleeper pipe number 1 on it!?!
But alas...I hear he sold it to some kook.
The following user(s) Liked this Post: MarkT, DVM
- Pete-RT1
Replied by Pete-RT1 on topic CT175 Milled head worth it?
In addition to all the other helpful advice and points people have made I would say the compression value you gave of 100-110 (I assume psi) sounds low.
Obviously I don't know what compression gauge you have, but with my very reliable Gunson gauge I get 150 psi across my range of 175 bikes.
It's also dependent on technique, so my readings are really to compare my own bikes to one another.
Here's a link which contains a video of my CT3 with a DVM copied sleeper exhaust which gave it a little pep, clutch was slipping a bit at the time.
Rider weight will have an effect on a small bike, I'm 182lbs for reference.
www.yamaha-enduros.com/index.php/forums/...730-ct3-sleeper-pipe
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, Ht1kid, Reed valve Richards, 84Prerunner
- 84Prerunner
Replied by 84Prerunner on topic Re:CT175 Milled head worth it?
Pete
Elevation change is always hard to see in videos for a true comparison, but yours definitely does look to have more torque than mine under say 5500rpm. mine is pretty gutless down there and really doesnt like short shifting. Why are you riding on the wrong side of the road though?? lol
With all the said, i was aware 110psi was a little low, i just figured the top end was a little tired but boy was i in for some surprises when i pulled it apart.
Very scored/damaged cylinder wall
Broken ring fell out of the exhaust, despite it currently have 2 in tact rings
had a .50mm over wiseco Yz/IT piston with bigger ports than the correct CT piston
Piston was in pretty rough shape as well
Cant tell if it has port work or not but i have another stock cylinder on the way.
Im shocked it ran as well as it did after seeing the internals
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid, Pete-RT1, Reed valve Richards
31 Oct 2026 15:20
#25
- Reed valve Richards
Replied by Reed valve Richards on topic Re:CT175 Milled head worth it?
84 Good to see that you 'know' what is going on in that little mill now - looks like a fun rebuild and then enjoy
Yo Joe, Go Joe
The following user(s) Liked this Post: Snglsmkr, 84Prerunner
01 Nov 2026 18:50
#26
- 84Prerunner
Replied by 84Prerunner on topic Re:Re:Re:CT175 Milled head worth it?
She’s back up and running. New piston, machined cylinder .5mm and took .012” off the deck surface. Ive only put 10 miles on it around the neighborhood but it feels like it has way more torque than before. Engine is much quieter than before, crazy difference.
Only thing I’m not liking is after the 10 mile test ride it has a random “ping” sound randomly at or near idle. Sounds like detonation at random but while idling? Going to check timing before it goes back out but I’m swamped with work tight now. Killing me not having time to ride it right after a rebuild.
Sent from my iPhone using Tapatalk
The following user(s) Liked this Post: MarkT, pabdt, Ht1kid
10 Nov 2026 22:14
#27
- DVM
Replied by DVM on topic Re:CT175 Milled head worth it?
Generally speaking a "pinging" sound is NOT good!! If this pinging sound is only during idle then I would slightly increase the size of the idle jet. Yes, checking the timing is a great idea to make sure it is not advanced. Adjusting the idle air screw to make the idle circuit richer could also eliminate the ping.
11 Nov 2026 12:06
#28
