Re:Re:CT175 Milled head worth it?
- 84Prerunner
Replied by 84Prerunner on topic Re:CT175 Milled head worth it?
haha! good to know. Its not that i don't believe he ran a 17tooth, just trying to verify its possible on mine. I was referencing Partszilla and dennis kirk which both list a 15 tooth as being OEM with a yamaha part number and dont list any 17 tooth as being available, only 13-16 tooth. Amazon shows china 17 tooth units that "fit" a CT but when i looked at mine the chain looked very close to everything around it with the 16tooth that is on it currently.
20 Oct 2026 16:18
#11
- DVM
Replied by DVM on topic CT175 Milled head worth it?
Thank you so much Mark for your kind words. Yes my CT3 ran very well! Unfortunately, my riding days are over due to my aging body (I am now 79 looking at 80 in a few months) and to be very honest, I REALLY MISS THOSE WONDERFUL YEARS OF THRILLS
. However, I have been working on Yamaha’s and enjoy doing so
. A few months ago I sold my beloved CT3 to forum member RickC for a favorable price along with my old 1965 Honda 305 Superhawk. I feel very good knowing my bikes went to a very, very good home.
The following user(s) Liked this Post: Rick C., MarkT, Snglsmkr, Ht1kid
- Reed valve Richards
Replied by Reed valve Richards on topic CT175 Milled head worth it?
Like Dogboy said I would have checked the sprockets to see if they were stock. As for my DT125 it does need to be in the band but it will ride in 6th but does loose power in wind and on hills but that said it belts along. That's one of the reasons I like the heaver xl250 as it's way easier to ride on pavement (and has a much better seat) , but once off road these old 2T are insane fun!
Yo Joe, Go Joe
The following user(s) Liked this Post: 84Prerunner
22 Oct 2026 19:07
#13
- 84Prerunner
Replied by 84Prerunner on topic Re:Re:CT175 Milled head worth it?
Took it out for 70 miles today. Being more prepared for the power delivery this time it did fine. Down shifting sooner, keeping it at 6-7500rpm was able to maintain 48-50 up hills with a headwind. It’s CRAZY how much just a head wind effects it, wouldn’t even pull 5th on one flat section but the head wind was blowing me around all over. Felt like I was doing 80mph when I was only doing 50
Still curious what the milled head would do but I’m in no rush to do that. It’s good enough!
Sent from my iPhone using Tapatalk
23 Oct 2026 20:07
#14
Replied by MarkT on topic Re:Re:CT175 Milled head worth it?
I would not mill the head. Or raise the compression unless it's to restore compression after porting the cylinder (raising the exhaust port reduces the "trapped" volume)
For some inscrutable reason, the Japanese decided to spec two stroke compression based on "trapped volume" after the ports close instead of using the conventional method of using the volume with piston at BDC.
(Four stroke exhaust valves often close after BDC but nobody lists the compression spec based on "trapped volume" after the exhaust valve closes)
So what looks like a "low compression ratio" on the spec sheet is actually around 11:1 if you measure from BDC.
Stock head is not the thickest or strongest casting. It's much better to mill the cylinder deck as DVM suggested as piston usually stops lower than the top of cylinder. Plus "squish clearance" is important and cylinder milling is often needed to optimize.
The following user(s) Liked this Post: Rick C., DVM, Snglsmkr, Ht1kid, 84Prerunner
24 Oct 2026 07:33
#15
Replied by Reed valve Richards on topic Re:CT175 Milled head worth it?
84 great that you got out again. I think the 175 should have pretty decent power, with these 6 gear 2T there IS a LOT of shifting compared to a 4T, a lot lot more, again it's not like the XL where you just shove it into 3rd go out for 3 hours and come home and yes it's still in third, lol
but the 175 is pretty peppy, I wonder if you are down in power a little, any chance you could jump on someone else's ride to check it out. If you watch Lakeman adventures over in Canada he is no small chap and he is flying up those steep rocky mountain trails !
Yo Joe, Go Joe
25 Oct 2026 01:37
#16
Granted its a DT175 and not a CT, riding starts at 13 minutes in, lol
Yo Joe, Go Joe
25 Oct 2026 01:40
#17
- 84Prerunner
Replied by 84Prerunner on topic Re:Re:Re:CT175 Milled head worth it?
I have watched a bunch of his videos, he rides the crap out of that DT!
I wish I knew someone with another CT to compare but I don’t. My CT being a 73 is only a 5speed, not 6.
In other news however I did discover some cylinder damage when I pulled the exhaust off to paint it. I’ll be digging in a little deeper but I can’t believe it still makes 110psi compression with the condition it’s in.
The following user(s) Liked this Post: Reed valve Richards
25 Oct 2026 07:05
#18
- DVM
Replied by DVM on topic Re:Re:Re:CT175 Milled head worth it?
84Prerunner,
If you choose to have the top of the CT3 cylinder milled down there are a few other things that can definitely improve the performance of your CT3. I would widen the exhaust port a couple mm. DO NOT remove any material from the top of the exhaust port!! Also, do not remove material from the bottom of the exhaust port. The next thing that will help would be to lower the intake port a few mm. When lowering the intake port I would ONLY lower the sides of the port, leave a good ½ inch of material in the center of the port. I personally used a half moon (half round) file to remove the material from the ports of my CT3.
Hope this helps.
Hope this helps.
- Mark350
Replied by Mark350 on topic CT175 Milled head worth it?
I have no dog in this fight on cylinder head milling, but just some insight. I put an MX 360 head (casting# 284) on my stock RT1-B back in the day. Wow, did it ever make a bunch more power. As to longevity??? bike was sold some months later.
25 Oct 2026 17:50
#20
