SLEEPER PIPES FOR YAMAHA ENDUROS
  • 's Avatar Topic Author
  • Visitor
  • Visitor
Replied by on topic SLEEPER PIPES FOR YAMAHA ENDUROS
We number the pipes so we can keep records on when they were built and what type cone we used etc...also anything special done with the pipe. Thanks for the kind words !
01 Feb 2016 14:47 #21
Replied by Pkreimer on topic SLEEPER PIPES FOR YAMAHA ENDUROS
Dave - got the pipe back Saturday and installed.
Looks and sounds great.
Haven't ridden it yet to give a review.
I will post again after I do that.
08 Feb 2016 06:40 #22
  • Visitor
  • Visitor
Thanks for the update......let us know once you get a chance to take a ride :OnFire
08 Feb 2016 09:00 #23
  • Visitor
  • Visitor
We are looking to do a few more Sleeper Pipes.....we are now doing the later 77-79 DT250/400
pipes with some great results !
So if your considering some added performance please contact me via PM or post up here !
Thanks again everyone for your support ! :OnFire
10 Feb 2016 11:39 #24
Dave (still haven't had a ride on the 250 yet, we have a thing called snow here),
Do you find the sleeper mod responds to any changes in the stock jetting on these bikes?
Particularly the 250A....
10 Feb 2016 12:36 #25
  • Visitor
  • Visitor
The Sleeper Pipe does not usually require jetting changes......its really a "plug and play"
situation. Although with your pipe I was surprised to find a lot of oil and unburnt fuel.
If you do a lot of slow speed riding that might explain it...if not you may want to lean your bike out some and or check to make sure your airfilter of airbox is not clogged. Also make sure your transmission side crank seal is good ?
I am excited to see how your bike responds to your new Sleeper Pipe ?
10 Feb 2016 13:17 #26
Replied by FrankC on topic SLEEPER PIPES FOR YAMAHA ENDUROS
Yipee!!!! 77-79. I am supposed to get a little money from the wife from the tax return this year.
10 Feb 2016 16:11 #27
Replied by Makotosun on topic SLEEPER PIPES FOR YAMAHA ENDUROS
This is most interesting. Once I get the DT400 back together with everything back to normal and running right, I may need to look into one of these babies. That bike is pretty nice right now, but I can only imagine if we were to open up the path to power just a tad bit, it would be amazing!
10 Feb 2016 17:59 #28
Replied by Bigdog302 on topic SLEEPER PIPES FOR YAMAHA ENDUROS
Meis, would you be willing to do a sleeper pipe for a 1978 DT175? Enduronut can give you the info on how the engine is set up with the porting and the head mod it has. it also needs the internal baffles to be removed and Enduronut knows where they are and how to remove them and where to cut and shorten the pipe to make the porting more effective.
the pipe also needs the part where it goes on the engine to be repaired as well. I have a RT180 pipe I can cut off the inlet and send it with the stock DT175 pipe.
Dave
Jesus is Lord!
Last edit: 16 Feb 2016 16:59 by Bigdog302.
16 Feb 2016 16:56 #29
  • Visitor
  • Visitor
We have no issue doing a DT175 sleeper pipe for you ....
the inlet will be an issue since we don't have a DT175 to test fit the inlet and pipe to.
Maybe you can cut off and tack weld the new inlet in place....we could then do the final weld?
I am sure your understanding my point.....
Let me know your thoughts ?
16 Feb 2016 18:51 #30
