Carb replacement - DT175E
- GTP091
Replied by GTP091 on topic Carb replacement - DT175E
I get the error “Failed To Create Attachment Directory.” When I try to post pics. Not sure what else to do for that. I forgot there was an o ring on the air mixture screw and it was melted by the carb cleaner. It’s been replaced. There is an oring between the needle and the main jet holder. I’ve never seen that before but Yamaha engineers are smarter than I am so it’s also been replaced. The only thing I can’t sort is how the pickup tube on the bowl for the choke fills with fuel. If I could post pics that would help for sure. There is what appears to be a brass metering jet of some sort at the bottom. The small hole on the side of this tube appears to allow fuel in, flow through this little brass jet, and get drawn into the brass pickup. It’s definitely not allowing fuel in from the hole. There’s no way to get this brass jet out. It looks to be a press fit. Maybe I’m overthinking it.
Replied by Gr8uncleal on topic Carb replacement - DT175E
To post pictures you need to use a third party host such as Imgur.
07 Jun 2024 08:06
#22
Replied by MarkT on topic Carb replacement - DT175E
The way you worded a previous post I thought you were saying you melted the air screw in carb cleaner.... my bad, should have clarified what you meant by "print".
That jet does not come out. You will destroy the float bowl if you try. And yes, the hole must be clear and allow fuel into the well.
07 Jun 2024 09:23
#23
- GTP091
Hmm thats what I had thought about the little brass unit in there being a jet. It’s all clean except for the jet itself. I’ll give it a go with the jewellers drill bit set I have. I would like choke to work.
I've used carb cleaner and 0.4mm copper wire in the past.
07 Jun 2024 12:50
#25
That particular model is almost impossible to start cold with a plugged starter jet... be careful not to make the hole bigger.
07 Jun 2024 15:39
#26
Replied by RT325 on topic Carb replacement - DT175E
If you start drilling be careful or you'll come out the bottom of the bowl.
Ok that's a bit radical or me being stupid--as usual.
Anyway--when you poke the fixed jet clear just poke in under it to be sure nothing is stuck under it.
Feeds in sideways from the bowl to under the jet.
I'm sure you know all that.
I did drill one oversize once with my smallest drill & sure richened it up too much.
Was ok for my bike & one kick cold start pretty much, but if you weren't aware & kept kicking she'd be well flooded up.
07 Jun 2024 16:27
#27
- GTP091
Thanks for the replies. Almost have it all back together. Looking forward to hopefully a nice braaaap braaaap!
13 Jun 2024 18:30
#28
- GTP091
Quick update on this. I got the choke jet cleared out. The carb is spotless now and is back on the bike. Need to get the fuel cock replaced and the clutch back together and should be good to go.
25 Jun 2024 21:53
#29
- GTP091
So. I got the clutch pack put back together, side cover stripped and painted, bolts polished up; looking good.. filled the tank and kicked it over with choke on. It fired right up with two kicks. Was happy with that as I’ve never had this bike run for more than a minute. It started to warm up and I put the choke in and started to sound lean and then died. Definitely starved of fuel but the throttle response was nice as it was going out. I was able to run it with chioke on no problem and it got nice and warmed up. But would die fairly quick without choke on.
my initial thoughts here would be a plugged pilot jet but I cleaned it out and could see daylight through it. Also weird was the idle screw had no effect on the rpm at all. I could screw it in all the way and no change. I’m not aware of the history of the bike at all really so will buy a new pilot from Yamaha and hope that’s the issue. I couldn’t read the # on it so maybe it’s way off.
gives me hope at least! Any other suggestions please share.
