1970 250 DT1C smoking bad and spitting oil out of exhaust connection after sitti
- Brettmac
1970 250 DT1C smoking bad and spitting oil out of exhaust connection after sitti was created by Brettmac
1970 DT1C smoking bad spitting oil on startup after sitting a few months
19 Nov 2022 19:41
Replied by MarkT on topic 1970 250 DT1C smoking bad and spitting oil out of exhaust connection after sitti
Easy fix. Ride it.
The following user(s) Liked this Post: SKYDANCER46, Ht1kid, Pedalcrazy
19 Nov 2022 19:49
- Brzn
Replied by Brzn on topic 1970 250 DT1C smoking bad and spitting oil out of exhaust connection after sitti
Oil's getting past the check valve on the autolube pump and filling the crankcase. Running it will clear it out. Or, the right side crankcase seal is allowing transmission oil into the crankcase. If that's the case, replace that oil seal.
20 Nov 2022 02:07
- asco
Replied by asco on topic 1970 250 DT1C smoking bad and spitting oil out of exhaust connection after sitti
Ride it for 20 minutes if still smoking change the right crankshaft seal.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
20 Nov 2022 06:50
- Brettmac
Replied by Brettmac on topic 1970 250 DT1C smoking bad and spitting oil out of exhaust connection after sitti
Thank you
20 Nov 2022 08:32
Replied by RT325 on topic 1970 250 DT1C smoking bad and spitting oil out of exhaust connection after sitti
If there's as much oil in the pipe as it sounds from what you describe, it'll smoke for a very long ride at speed to dry it out. This smoke doesn't relate to motor condition so don't worry if it sounds & feels good.
20 Nov 2022 19:07
- Brettmac
Ok thank you seems to be burning transmission oil. Might have to replace a seal hopefully don’t have to split case
20 Nov 2022 19:58
Sorry to be a pain but what makes you say 'that'--trans oil. I'm all for leaving well alone, but if it's dissapearing then ok. Robust seals on 250's & 360's. Likely mine is still on original. Keep oil in the autolube tank though if it's drained into the motor over time. Crank seal isn't too difficult but clutch will need to come off as the crank gear won't clear the basket.
The following user(s) Liked this Post: MarkT, Ht1kid, YamahaForumUsername
21 Nov 2022 00:32
