RT3 will not start - SOS
Replied by RT325 on topic RT3 will not start - SOS
yep check it & at least can eliminate that as a cause.
14 Oct 2021 19:02 #11
Replied by MarkT on topic RT3 will not start - SOS
If you found oil in the pipe it's likely just loaded up with old oil from sitting...  it'll clear out.
Just in case, check and make sure trans oil level isn't dropping.
14 Oct 2021 19:21 #12
  • Jogar
  • Jogar's Avatar Topic Author
Replied by Jogar on topic RT3 will not start - SOS
The flywheel still turns when I kick, Key is intact
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
14 Oct 2021 20:17 #13
  • Jogar
So just kick over and over again for a few hours until it clears?
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
14 Oct 2021 20:18 #14
Replied by asco on topic RT3 will not start - SOS
Bikes that pop and stall out usually have a grain of sand blocking the pilot jet.
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: Jogar
14 Oct 2021 20:21 #15
Replied by apex on topic RT3 will not start - SOS
Flywheel turning with a kick over doesn't necessarily mean the key hasn't sheared and the flywheel is off time. Need to pull the flywheel and see if the key has sheared/flywheel slipped to be 100% sure. Your symptoms sound to me like the key has sheared.
Allrighty Then
The following user(s) Liked this Post: RT325, Jogar
14 Oct 2021 22:41 #16
  • Jogar
Edited: got the flywheel off gently but firmly haha. Key is in fact sheared . Going to try to find one that will fit in town today. I’ll post updates as they come. Thanks everybody !
You couldn’t be more right… I took it the nut and the flywheel retainer nut off, and I can’t get the flywheel off now. Must have sheared or slipped like you say. Now what would be a creative way to pry it off of the engine without destroying everything else?
lol
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
Last edit: 15 Oct 2021 10:12 by Jogar. Reason: Got the flywheel off
15 Oct 2021 09:49 #17
Replied by DEET on topic RT3 will not start - SOS
Warning!
Do NOT use anything other than the correct flywheel puller ($15)
Otherwise you will be crying when you destroy the coils underneath the flywheel.
15 Oct 2021 10:11 #18
  • Jogar
I’ve been crying this whole time, but yes I have the motion pro!
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
15 Oct 2021 10:13 #19
Replied by 1971DT250 on topic RT3 will not start - SOS
My experience:
The 360 is harder on these parts than the 250 because of the stronger kickback. I see more sheared keys on the 360s than the 250s. When this happens the damage to the taper on the shaft and taper in the flywheel makes it more likely to happen again. It is the mating of the surface area between them and the proper torque on the nut that gives the holding power. If the contact area is reduced by damage and then removing metal it will have less holding power. I use valve lapping compound and gently spin the flywheel. Then put chalk inside the flywheel and slide it on without spinning it, pull it off and see if the taper on the crankshaft is covered with no voids. The key is not what holds and prevents the flywheel from spinning on the shaft, it is to keep it lined up while tightening the nut. Having the timing set properly and a functioning decomp valve (not plugged up with soot) will help reduce the kickback.
The following user(s) Liked this Post: MarkT, HouseofEnduro, Sneezles61
15 Oct 2021 11:55 #20
