Air and idle 73 dt3
Replied by RT325 on topic Air and idle 73 dt3
Don't forget the points gap--15 thou just nipping on the feeler blade. Eyeball that before pulling the flywheel & if the key is all ok then please fully tighten the nut as they're hard on keys otherwise. Hope you have a proper puller 27x1mm pitch left hand thread. Sorry if this has all been covered, just thought i'd add it incase without reading back tonight.
08 Sep 2021 05:12
#41
Replied by MarkT on topic Air and idle 73 dt3
RT325, my memory is slipping but I think this might be the bike that wouldn't start until the plug gap was narrowed way down. Also had a BR plug and presumably a resistor cap. Not sure if that was corrected. There were other signs of possibly weak ignition. Videos posted are of idling but not of the bad running it supposedly does when revved up. However, comment was made on another thread that this bike sounds the same and that bike sounded like a bad CDI to me.
This bike obviously doesn't have a CDI, but as you know a bad condenser can create a bad misfire even if it starts okay. I don't recall if condenser was changed or the condition of the points and the condenser question I asked a few posts back wasn't answered.
Long winded way to say I agree it might be ignition related?
08 Sep 2021 05:48
#42
- principal282
Replied by principal282 on topic Air and idle 73 dt3
Found it.
slipped crank key
new one ordered.
Found it.
slipped crank key
new one ordered.
slipped crank key
new one ordered.
Found it.
slipped crank key
new one ordered.
08 Sep 2021 14:59
#43
- principal282
Tried a locally sourced key.
still coughs and spits. Could the timing have gotten messed up?
Video to follow
Video to follow
08 Sep 2021 16:26
#44
- principal282
08 Sep 2021 16:27
#45
- principal282
Condenser and points were new this spring. I haven't tested lately.
08 Sep 2021 16:34
#46
Replied by Ht1kid on topic Air and idle 73 dt3
I wonder from the photo if your blue wire or points wire is shorted out looks awful close plus the timing needs to be checked with the new key installed
08 Sep 2021 17:32
#47
Ok, was the key broken or just halfway. Did you sit it back together just for the pic. Definitely ignition misfire now so have you set the points gap to a reasonable gap when open. Look in the dark in at the flywheel when running & tell us what shows. Looks like the ignition source has a wipe across some windings which might be a clue but even more clue-ee is the wire to the points to condenser has rubbed through on the side so could be arcing to the flywheel when running. Over to MarkT--whatda ya recon? Think i've missed a few comments, catchup time.
The following user(s) Liked this Post: Ht1kid, principal282
Also is the solder from your condenser touching the outer part of your condenser I don’t think it would start if it was but who knows maybe?
08 Sep 2021 17:38
#49
Sorry HT1kid, hadn't read yours--maybe its a blue wire cheers.
08 Sep 2021 17:38
#50
