Screws Came Out of Speedometer Face
- Slipkid
- Topic Author
Screws Came Out of Speedometer Face was created by Slipkid
This is a personal first, but I bet it's happened to someone else before...
On my 1975 DT250, the internal screws that hold the face to the speedometer somehow managed to vibrate completely out. This has led to the face turning sideways, and the screws rattling around at the bottom of it. Not good...
I know these units are crimped together and not made to come apart.
If I could get it apart, it should be a pretty simple thing to remedy though.
So question is, can anyone relate the least painful/destructive method for getting the speedometer apart and back together?
- KennyV
Replied by KennyV on topic Screws Came Out of Speedometer Face
These are my homemade "can opener" tools I made for opening up tachs and speedos. I first wrap several layers of masking tape to protect the chrome and then slowly and carefully start working the crimped edge open. I use an old worn out / worn smooth pair of pliers to carefully re- crimp. If you're not comfortable doing this you can always send it to DEET, he's the tach and speedo master!
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
21 CRF300l Rally
The following user(s) Liked this Post: mdscott, Slipkid
02 Jun 2020 06:42
- yamahoper
Replied by yamahoper on topic Screws Came Out of Speedometer Face
The screws will cause damage. You can see the wear mark arcing accross the bottom of my gauge from a single screw dancing around for about 400 miles of riding.
I was on the second day of an enduro fest when it came out. I should have removed the tach for the duration of the trip.
Here are my tools . The screw driver has better leverage . I started with the paint can pry tool , it was ready to go.
I have since had to get into several gauges some more than once. Now I just crimp over 4 small sections to make it easy the next time. The rubber edge gaurd keeps the dust out quite well without a full crimp around.
The following user(s) Liked this Post: MarkT, mdscott, Slipkid
02 Jun 2020 07:39
- mdscott
Replied by mdscott on topic Screws Came Out of Speedometer Face
Like Kenny and Yamahopper says it’s a slow process, and patients is a virtue.
the first one I did I neglected to put tape on the housing, scratched it but luckily the rubber piece covered my mistake.
Scroll to #160, and 164. Mine completely came apart.
yamaha-enduros.com/index.php/forums/rest...esto-dt360?start=150
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'02 Honda XR70R
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'02 Honda XR70R
The following user(s) Liked this Post: Slipkid
- Slipkid
- Topic Author
Replied by Slipkid on topic Screws Came Out of Speedometer Face
Thanks for the replies fellas, I think it looks pretty doable.
The pics of various tools used was very helpful.
Confident I can get this done...
02 Jun 2020 08:10
- mdscott
Face plates are available if yours is in bad condition.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'02 Honda XR70R
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'02 Honda XR70R
02 Jun 2020 08:15
- Roadking
Replied by Roadking on topic Screws Came Out of Speedometer Face
Seems to me that there are instructions somewhere on the site. I took mine apart and repaired it, wasn’t too difficult.
2020 Yamaha XT250
1997 Harley Davidison Roadking
02 Jun 2020 13:32
- Slipkid
- Topic Author
Well, I got 'er done! No big deal really...
I just progressively pried around the edge of the bezel with a paint can opener until it was wide enough to slip off, reattached the screws with some Loc-tite, replaced the bezel, and re-crimped it with a set of pliers that I'd taped the jaws on.
The following user(s) Liked this Post: MarkT, 2fishkev, mdscott, KennyV
29 Jul 2020 10:12
- john_sender@yahoo.com
Replied by john_sender@yahoo.com on topic Screws Came Out of Speedometer Face
Does anyone know where you can get the speedometer faceplate screws. I was assuming they would be floating around in the speedo but they are long gone.
Thanks !! Just wrapping my mind around my 74 DT 360.
20 Aug 2020 18:09
- Evman100
Replied by Evman100 on topic Screws Came Out of Speedometer Face
Did you ever find the faceplate screws?
08 Nov 2023 11:15
