Does a 1974 Yamaha DT175 have a voltage regulator?
- JohnPaul
Does a 1974 Yamaha DT175 have a voltage regulator? was created by JohnPaul
I keep blowing bulbs at high revs and sometimes low revs and I can't get the lights to come on steady (i.e. getting brighter when revving} I have looked and looked and cannot find a regulator anywhere on this bike or on the manuals. Someone help please!
18 Feb 2020 09:38
Replied by Gr8uncleal on topic Does a 1974 Yamaha DT175 have a voltage regulator?
Your wish is our command! See link below regarding retro fitting of 6v voltage regulators.
yamaha-enduros.com/index.php/service-bul...e-voltage-regulators
18 Feb 2020 10:20
- DEET
- Moderator
Replied by DEET on topic Does a 1974 Yamaha DT175 have a voltage regulator?
This may help.....
18 Feb 2020 10:27
- JohnPaul
Replied by JohnPaul on topic Does a 1974 Yamaha DT175 have a voltage regulator?
DEET... you're a legend.
The following user(s) Liked this Post: DEET, Rick C.
18 Feb 2020 10:41
- JohnPaul
Hey deet, what year is that paper from? I think I don't have a voltage regulator.
18 Feb 2020 11:47
Partzilla shows the 1976 DT175C as the first one to have a voltage regulator fitted as standard, hence Yamaha's own bulletin that I posted the link for.
18 Feb 2020 12:10
- JimA
Replied by JimA on topic Does a 1974 Yamaha DT175 have a voltage regulator?
My 1975 DT 175 has a voltage regulator. It's under the tank in front of the flasher.
I take that back it is a rectifier.
- JohnPaul
Would you mind sharing a photo?
18 Feb 2020 21:00
- JimA
The Rectifier ( diode) is actually above the flasher with the red and white wires. It is not a part of the head light wiring.
18 Feb 2020 22:47
..........and shouldn't be confused with the voltage regulator that you are enquiring about.
The following user(s) Liked this Post: RT325, JimA
18 Feb 2020 23:53
