turn light switch DT2
  • htw123hotmail
  • htw123hotmail's Avatar Topic Author
turn light switch DT2 was created by htw123hotmail
I have a DT2 turn light switch in good condition but the plastic high beam/low beam select button has broken off. Any suggestions on how to find that part or get it repaired for a reasonable cost? I think the switch is pretty much the same for all of the early Yamaha enduros.
thanks!
15 Feb 2020 08:15 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic turn light switch DT2
Is it the black "toggle" that you operate with your thumb that has broken, or the top of the switch that sits inside the housing and protrudes out of the top and to which the black "toggle" is attached by way of a screw?
DEET might be able to help out, I think.
15 Feb 2020 08:35 #2
  • htw123hotmail
Replied by htw123hotmail on topic turn light switch DT2
yes, the black toggle switch has broken off along with the piece of metal that holds it in place.
15 Feb 2020 09:08 #3
  • htw123hotmail
both pieces are gone
15 Feb 2020 09:09 #4
Replied by DEET on topic turn light switch DT2
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=351739056076&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=312200717692&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • htw123hotmail
should work on the DT2? Awesome!
15 Feb 2020 09:21 #7
Replied by Lizeec on topic turn light switch DT2
If you are missing the black toggle lever itself 9 times out of 10 the actual switch itself is also broken where the black toggle lever screw attaches to. Not sure if you an get the switch itself, might be easier to locate a complete LH handlebar switch assy.
15 Feb 2020 09:41 #8
  • Gr8uncleal
Yes, that's what I was trying to get at! :likey
The top of the internal switch on all bikes of that era are very prone to snapping off.
An awful lot of Yamahas of that era used the same basic housing (stamped YHA 205 on the underside, I think) in various permutations.
15 Feb 2020 09:49 #9
Replied by MarkT on topic turn light switch DT2
Check this thread for a Kawasaki part that reportedly works to replace the oft-broken stub the knob screws on to.
yamaha-enduros.com/index.php/forums/gene...parts-the-same#72620
15 Feb 2020 10:11 #10
