Clutch actuator assembly with broken nylon needed.
- KennyV
Clutch actuator assembly with broken nylon needed. was created by KennyV
The nylon part of my RT2 clutch actuator is cracked and it's only a matter of time before I'm going to need to fix it. I posted this idea on Mausers thread, yamaha-enduros.com/index.php/forums/1972...w-split-rt2?start=30 . I've been thinking about a fix to replace the threaded nylon piece. Chasing a triple lead thread on my lathe doesn't look like a problem. I'm not sure how or if a new nylon piece can be attached and locked to the metal part of the actuator. This is where I need help. If anyone has a broken actuator assembly, broken as the nylon is separated from the metal, and doesn't mind sending to me I'd much appreciate it! In return, if I can come up with a fix, I'll send it back fixed.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
21 CRF300l Rally
The following user(s) Liked this Post: MarkT, RT360Fan
- DEET
- Moderator
Replied by DEET on topic Clutch actuator assembly with broken nylon needed.
I probably have a few.
Send me your address.
11 Dec 2019 14:25
- DEET
- Moderator
I may even have a stick of Delrin....
11 Dec 2019 15:48
- KennyV
Replied by KennyV on topic Clutch actuator assembly with broken nylon needed.
Thanks!!!
71 Z50 Minitrail
21 CRF300l Rally
21 CRF300l Rally
11 Dec 2019 16:43
- DEET
- Moderator
Going in the mail Dec. 12
11 Dec 2019 18:50
- darinm
Replied by darinm on topic Clutch actuator assembly with broken nylon needed.
Mauser sums it up, it's a press fit and the shaft has ribs or splines depending on the terminology you prefer. I know because Marble Motors briefly re-popped them in too soft of a plastic, I bought one and ended up epoxying mine on to the shaft for that bike because as shipped it spun on the shaft.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
11 Dec 2019 19:06
