72 DT2 250
  • GarysDT2
  • GarysDT2's Avatar Topic Author
72 DT2 250 was created by GarysDT2
Retired boomer in Virginia restomoding the bike my dad bought new for me as a teenager. I wrecked it on the street doing something stupid and it has been a basket case for over 50 years. I have been going through a downsizing phase and had to make a decision about what I was going to do about the bike. I agonized between selling it as is with many parts in excellent shape or going for the restoration. My heart won out over my head so I'm going for the restoration. Watched many restorers on YouTube and hopefully with this forum I will be successful.
The following user(s) Liked this Post: Ht1kid, pahiker
12 Mar 2026 16:22 #1
Replied by pahiker on topic 72 DT2 250
Welcome and good luck with your restoration. You'll want to put on a regulator to prevent blown lightbulbs per this tsb. www.yamaha-enduros.com/index.php/service...e-voltage-regulators
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
The following user(s) Liked this Post: GarysDT2, DonTeeAus
12 Mar 2026 16:34 #2
  • GarysDT2
Replied by GarysDT2 on topic 72 DT2 250
That was quick! and thanks for the response. I read what you suggested and this won't apply to me if my plan works out. Part of the "mod" of my restomod is to convert to a 12VDC electrical system and leaving the ignition system intact. One question I have that I haven't been able to figure out from the schematic is there is a white wire in the bundle coming from the stator that I can't account for in the drawing. I know there is a white wire going to the original rectifier where either the Daytime or Night time charging circuit is selected but that comes from the ignition switch. I looked in the forum to see if that topic has been discussed but couldn't find anything that specific. I'm a newby so should I just post this in the main topic section to see if any gurus out there know the answer?
12 Mar 2026 17:32 #3
If it's  a white wire that's unattached, it may be the wire to increase the charging rate on the battery. See page 93 of the service manual for details. www.yamaha-enduros.com/index.php/service...360cc-service-manual
1973 Yamaha RT3
2024 Suzuki DR650
The following user(s) Liked this Post: MarkT, Snglsmkr, Gr8uncleal, GarysDT2
12 Mar 2026 17:57 #4
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 72 DT2 250
 from near Salisbury, UK.
Great that you still have the bike, even if it's in boxes!
I agree with pahiker re the spare white wire. Also, there will be a spare black wire exiting the stator harness about half way up. This is not an earth, and if you connect it to other black wires your bike won't run! Apparently it's for testing some aspect of the ignition system.
You will, of course, be replacing both sets of brake shoes! New ones are still available from Yamaha and CMSNL and Partzilla should have the current part numbers. I can't be sure, but the originals might contain asbestos, so take care with their removal and disposal.
The following user(s) Liked this Post: Ht1kid, GarysDT2
13 Mar 2026 01:30 #5
  • GarysDT2
Was watching 2Vintage on YouTube last night the episode where he is working on a DT2 360. He was resolving an ignition issue and was tracing out the electrical system and he pointed out that the white wire I was asking about was not connected. I read your suggestion and I'm grateful for it. The 12VDC rectifier/regulator I'm going to try for the electrical mod has 2 AC inputs so I'll connect the white wire and the green/red wire (night time charging circuit) to those inputs.
The following user(s) Liked this Post: Reed valve Richards
13 Mar 2026 05:08 #6
Replied by Swoop56 on topic 72 DT2 250
There isn't any point in attaching both wires . They are fed from the one coil ,
and are just connected at different points of the windings .
The white wire will give the maximum output . the two together will still only supply the same output .
The following user(s) Liked this Post: RT325, GarysDT2
13 Mar 2026 12:28 #7
  • GarysDT2
Thanks for checking behind me. I'm going to use the Yellow Headlight circuit and the White wire as my 2 AC inputs.
13 Mar 2026 16:18 #8
Replied by DonTeeAus on topic 72 DT2 250
One thing I found when building a harness for my DT2 was that you need to be careful with your wiring diagrams you get from the 'net. Early DT1 and DT2 I think are the same but DT3 and beyond are a bit different however most wiring diagrams I found (including in my workshop manual) were for the latter bikes.
I think for the DT2 all wires coming from the lighting/charging coils should be connected thru the ignition switch (which switches lights on and off) and the white wire is the charging output used when the lights are on. But I'm not at home to check and it was a while ago that I nutted it out.
I played with a 12V no battery AC lighting setup but found it easier to just go standard 6v and run the battery. I don't however intend to use the bike at night, it only needs rego to comply with our historic vehicle registration requirements.
26 May 2026 01:09 #9
  • GarysDT2
Thanks for the response. I've familiarized myself pretty well with the electrical system and how everything works through the ignition switch. I had to replace the main switch assembly (turn signal, H/L beam, horn) so I had to interface that into the existing wiring harness, not a big deal. I have installed a 12V battery and checked its functionality with 12V LED bulbs. The only thing left is to verify the 12V regulator and that will happen when the miracle of my engine running again happens.
The following user(s) Liked this Post: DonTeeAus
26 May 2026 05:43 #10
