Re: Oil pump removal
Replied by RT325 on topic Re: Oil pump removal
Sorry DEET, try this. Thought maybe best if i didn't link a cheapy & steer people away from your expert restorations of them. Then again with these you might have a never ending row of ones to fix. Please don't retire anytime soon. Cheers.
www.aliexpress.com/item/1005009211185069...%7C_p_origin_prod%3A
www.aliexpress.com/w/wholesale-yamaha-tr...productlist.search.0
- john.lockwood5@bigpond.com
Replied by john.lockwood5@bigpond.com on topic Re: Oil pump removal
So, does anyone know the relevance of the washer mentioned in an earlier post?
I think it goes on the end of the input shaft into the pump.
What happens if it’s not there?
27 Oct 2026 18:25
#12
- Dirt clods
Replied by Dirt clods on topic Re: Oil pump removal
Dale Sweger Motorcycles Youtube washer
1974 and up Yamaha DT125 DT175 oil pump washer
@montana2strokeracer
28 Oct 2026 17:56
#13
Thank you Dirt Clods, perfect.
The following user(s) Liked this Post: Dirt clods
28 Oct 2026 18:56
#14
Replied by MarkT on topic Re: Oil pump removal
Always check carefully. Sometimes "stiction" retains the washer.
28 Oct 2026 21:54
#15
I'd Just be careful fitting one if it wasn't there when you pulled the pump.
I mean be careful incase adding the washer stops the pump closing right up.
Don't want to break the ears off tightening it if end clearance doesn't allow for it on 'yours'.
Love Dale's videos though. Goes above & beyond to be helpful.
29 Oct 2026 14:00
#16
- Dirt clods
UPDATE
The leak wasn't necessarily coming from the pump itself, but from around the brass fitting where the oil induction line enters the oil pump.
What tipped me off was noticing that the replacement oil pump had what appeared to be epoxy sealing around both brass fittings. That gave me a clue that those fittings might be a potential leak point.
So heres what I did
Applied JB Weld around both brass fittings.
Allowed it to cure.
Installed a new gasket.
Reinstalled the oil pump.
Confirmed that the leak stopped.
Sometimes the hardest part of an old-bike repair isn't fixing the problem; it's figuring out exactly where the problem is coming from!
Note: The new pump would work but I wanted to stay with the OEM
So heres what I did
Allowed it to cure.
Replied by Gr8uncleal on topic Re: Oil pump removal
Thanks for the update.
04 Nov 2026 06:46
#18
