1974 DT 360 floats-missing parts?
  • 2strokenewb
  • 2strokenewb's Avatar Topic Author
1974 DT 360 floats-missing parts? was created by 2strokenewb
so I am going through my carb among other things on the lovely 360 I inherited. It appears to be the original 3300 mile carb that the bike came with. These carbs have 2 individual floats that run up and down on 2 "posts" that are pressed into the bowl. each post has a groove machined into the top. I came across a picture that showed some sort of little brass cap or acorn looking thing at the top of that post with the floats installed.. I can't find any parts manual or breakdown that shows these parts. any ideas? are they needed for the floats to function?
24 Nov 2024 05:10 #1
Replied by Gr8uncleal on topic 1974 DT 360 floats-missing parts?
I don't believe that they affect function, but are belt and braces to keep the floats in place when reassembling.
The following user(s) Liked this Post: MarkT, Schu, 2strokenewb
24 Nov 2024 06:29 #2
Replied by MarkT on topic 1974 DT 360 floats-missing parts?
Not needed
The following user(s) Liked this Post: 2strokenewb
24 Nov 2024 09:33 #3
Replied by RT325 on topic 1974 DT 360 floats-missing parts?
I'm sure i don't need to mention--but anyway-- the side pin on the floats goes at the bottom.
Saw someone at work once assemble them up the other way so the pins contacted the float arm at rest & kept the valve shut so no fuel entering.
24 Nov 2024 18:37 #4
Not meant to confuse but oddly enough "some" Mikuni carbs actually need the pins on the top of the float...  I believe it's some of the the larger body versions that are made this way...
So now forget what I said and do what RT325 suggested...  I just wanted to point out that some Mikunis you might come across are bass ackwards so it's a good idea to note it when disassembling if you can remember.
24 Nov 2024 19:30 #5
Sounds like a dissagreement brewing Mark haha.
I hate appologising, so without stiring the pot i'd like to see evidense of that.
Sorry if that sounds terrible, not meant to be. bit of fun--umm--till i lose!!.
24 Nov 2024 19:36 #6
I like the videos this guy does. Goes to the extreme to explain things.
I must admit dragged it along but could be worth a watch for those needing general carb info for older yamahas.
All his videos i've stumbled on while searching have been great.
The following user(s) Liked this Post: pahiker, 2strokenewb
Last edit: 25 Nov 2024 00:04 by RT325.
25 Nov 2024 00:02 #7
Floats may well have fitting orientation on them - see link.
FLOAT for DT360 1974 USA - order at CMSNL
Last edit: 25 Nov 2024 07:07 by Gr8uncleal.
25 Nov 2024 01:47 #8
  • 2strokenewb
Replied by 2strokenewb on topic 1974 DT 360 floats-missing parts?
well, I don't have the parts, so it's more than likely going together without anything. I may try and find a small E clip that fits
25 Nov 2024 04:35 #9
Brand new Mikuni carbs with the float pins no longer come with the retaining caps, even though the pins have the same ends that could accept a cap.  Not needed as Gr8uncleal said.
RT325, I'm not going to argue on the floats...  could easily be my memory fooling me and I don't have any of the larger Mikuni carbs to check.
25 Nov 2024 06:06 #10
