1974 dt125 to 175
Replied by MarkT on topic 1974 dt125 to 175
Check recent post from DVM... I thinks he's selling what you want. (Not sure why you want a CT3 cylinder when you already have what you said was a good DT175 cylinder?)
Anyway, post was something like "members near Orange County". DVM is a great guy and has one of the best running CT3's I've ever ridden. You can ask if he'll ship to you.
The following user(s) Liked this Post: DVM
06 Jan 2024 08:07 #11
  • Enduro Rod
  • Enduro Rod's Avatar Topic Author
Replied by Enduro Rod on topic 1974 dt125 to 175
Thanks mark the reason is because a ct3 cylinder and head to match like you suggested. Is a dt175 piston compatible with the ct3 porting. Thanks for your help
06 Jan 2024 08:24 #12
  • Enduro Rod
                                                  What I don’t like about the Dt175 cylinder is that the tach drive cable
                                                    Isn’t clearanced in the cylinder and head.  Thanks for your time
thing
06 Jan 2024 08:44 #13
If there is no tach cable fin clearancing then I'm pretty sure you do not have a DT175 cylinder.  The 74 cylinder definitely had clearancing.
06 Jan 2024 10:07 #14
  • Enduro Rod
                                                 Sorry about typing. Tachometer comes out on a major different angle
                                                  On the dt175 than the dt 125. I think the ct3 comes out just like the
                                                  74 dt125. I seen the bike it came off of
06 Jan 2024 10:18 #15
Replied by Ht1kid on topic 1974 dt125 to 175
Can you post some pictures that would help you have to use a third party Imgur, google photos etc
06 Jan 2024 11:05 #16
  • Enduro Rod
                                                    I don’t usually don’t usually do anything like this. I wouldn’t know
                                                      Post pics other than direct. Tried to change avatar and that doesn’t
                                                      Work ether. I will just get a ct3 cylinder. DVM doesn’t send so I will
                                                       The 125 runs great. Totally rebuilt. Does the 175 have a lot more
​​​​​​                                                       Power than the 125 or a waist of money? Thanks
06 Jan 2024 13:11 #17
Replied by DVM on topic 1974 dt125 to 175
The 175's have LOTS more power than the 125's! You would love the boost in power.
06 Jan 2024 13:52 #18
  • Enduro Rod
                                                     Thanks that’s what makes it worth while! Will the electric start still
                                                     Turn the motor over? I have a AGM battery with double cca over
                                                     Stock!  Thanks Rod
Last edit: 06 Jan 2024 14:08 by Enduro Rod. Reason: Something to add
06 Jan 2024 14:03 #19
I have seen 125's upgraded to 175's crank over with no problems but no guaranties.
DVM
06 Jan 2024 15:19 #20
