74 DT250 clutch cable
  • MrBernzo
  • MrBernzo's Avatar Topic Author
74 DT250 clutch cable was created by MrBernzo
The clutch cable on the DT just broke.
I am struggling to find a replacement specific to the model.
The outer on mine is 118cm long. Are there any cables from other models that I can use?
26 Dec 2023 20:02 #1
Replied by Steve F on topic 74 DT250 clutch cable
So I did a few google searches and was able to find a few cables on ebay and also located one nos in UK. Prices are a bit stiff, but if you need it, find the lowest cost one and buy it if price matters. Really sad to see some of this stuff going for crazy prices. Sign of the times and availability. Personally if it was my bike I would contact Motion Pro and see if they could or would quote to build one for you. I had them build a tach cable for me some yr's back for my DT250A and it was a perfect fit and is servicing well. 9 yr's now. Good luck with your search.
1974 DT250A
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
"And there ya have it"
The following user(s) Liked this Post: MACE6772, MrBernzo, Schu, Sneezles61
27 Dec 2023 08:32 #2
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 74 DT250 clutch cable
If I recall correctly, you can fit the one from the DT250/400 (1975/76) if you're prepared to compromise on the routing - I think that this later cable is a tad shorter.
The following user(s) Liked this Post: MrBernzo
27 Dec 2023 09:28 #3
Replied by RT325 on topic 74 DT250 clutch cable
If ya desperate to go riding & it broke at the nipple at the top end then try one of these.
www.carbuilder.com/uk/solderless-nipple
If you have soldering capabilities the here's some options.
www.venhill.co.uk/cables-and-components.html
www.carrotcycles.co.uk/control-cable-par...pples-/imperial.html
The following user(s) Liked this Post: MarkT, MrBernzo, Ht1kid
27 Dec 2023 17:38 #4
  • MrBernzo
Replied by MrBernzo on topic 74 DT250 clutch cable
Thanks, I'm looking for new if possible. I will reach out to motion pro if I can't find other alternatives.
30 Dec 2023 02:20 #5
Replied by Enduro nut on topic 74 DT250 clutch cable
So im seeing 2 different part numbers here. If you use Babbitts diagram you'll see under #33 part # 363-26335-00 which i see some on ebay under that number. If you go into the tech library, parts list here on the site you'll see listed under #27 Part # 438-26335-00 which on ebay you will see new ones for around $100.
Then you have the ones where they say "it fits" for around $20 but we all know how that goes. Years 74-76 DT250/360 and 400 should use the same clutch cable but you would have to cross reference the parts numbers to be sure.
01 Jan 2024 16:59 #6
  • Gr8uncleal
Pretty sure that the 1974 was a one year only part number and it is the one starting 438.
As per my previous post, the 1975/6 can be used, but correct routing is compromised (I think the later part is a tad shorter).
01 Jan 2024 23:30 #7
Replied by Gmac on topic 74 DT250 clutch cable
I built a DT250 rat bike with a 75 frame and 74 motor and used a Parts Unlimited clutch cable Part # K282531. Keeping in mind that the bars I used were lower than stock and it works well.
02 Jan 2024 12:05 #8
Did the cable change from pulling under the motor to pulling from the top. Actuator changed sometime but not sure when.
02 Jan 2024 13:45 #9
The cable end fits in to a boss that is cast in to the case ahead of the clutch lever actuator arm. On my 74 / 75 and probably the 76 there is no other option for the clutch lever to be operated. The clutch cable follows the Lh down tube and proceeds to go under the motor right by the exhaust pipe.
The following user(s) Liked this Post: RT325, MACE6772
02 Jan 2024 14:39 #10
