sudden timing issues?
  • Digger65
  • Digger65's Avatar Topic Author
Replied by Digger65 on topic sudden timing issues?
ok managed to source a shaft for 17 bucks stateside
imgur.com/a/EQdq8nt
the crankcase is off to be shimmed £100 as per below
imgur.com/a/0Q8nvdQ
D
24 Aug 2023 09:53 #121
  • 's Avatar
  • Visitor
  • Visitor
Replied by on topic sudden timing issues?
See if you can find a bearing with slightly larger OD. Machine so it fits.
24 Aug 2023 10:12 #122
  • Digger65
its being shimmed with stainless steel insert same id as bearing od
thought might be possible to JB weld and maybe washers either side perhaps to secure it but decided worth getting done properly, managed a good price on the shaft considering between £150-£180 new
Last edit: 24 Aug 2023 10:37 by Digger65.
24 Aug 2023 10:35 #123
Replied by Ht1kid on topic sudden timing issues?
I would let the machine shop install your new bearing for a good tight fit
24 Aug 2023 16:35 #124
  • Digger65
yeah he has the case and bearing
worked on loads of 2 strokes so knows the score
D
25 Aug 2023 15:13 #125
  • Digger65
imgur.com/a/eMHJsI7
quick question as should be getting back together once all the bits arrive
can i ask the routung of 16 in image above
as it was apparently justin casing when i took apart
presume it runs inside the shaft the clutch attched to?
cheers in adv
D
29 Aug 2023 01:16 #126
  • Digger65
imgur.com/a/ubFFvOl
casing back, happy with the work
waiting on the shaft then back togeher and another round of annoying questions no doubt
D
07 Sep 2023 12:25 #127
